Brake issues
Old May 9, 2019 | 07:10 PM
Arsoncop's Avatar
Arsoncop
Brake issues
Did a complete brake system replace ( not the hoses) on my 73 F250 highboy, its a project and needed new brakes so I replaced everything. I adjusted the brakes or at least I thought I did and then bled the fluid. The front brakes will stop but the rear brakes have no brake. The truck is up on jack stands so I can turn the tires. Do you turn the adjustment screw up or down to widen the brakes ? I have turned them both ways and it doesn't seem to make a difference. When you pump the brake pedel I can see the adjuster moving though the little hole. I am going to be really ill if I have to take the drums off to fix the problem, hoping it is something simple. Thanks
Old May 10, 2019 | 08:09 AM
Randy Nix's Avatar
Randy Nix
I Did all my brake components over a year ago. Is your MC new?
Make sure to adjust the rear pads to touch the drums just enough to stop them from rotating by hand..
Then back them off just enough to free up the drum until it rotates easily. Even if the pads are barely touching the drums its ok.
The rear cylinders don't move a lot so the pads need to be as close to the drums as possible.
Good Luck.
Old May 10, 2019 | 09:04 AM
Tedster9's Avatar
Tedster9
Yep, run the adjusters up all the way as far as they will go. Depress the brake pedal a few times to center the mechanism and take some of the slop out. The rear brake shoes need to be manually adjusted to achieve a "light drag" against the drums or the brake pedal will be low and mushy. If they "spin freely" you're doing it wrong.
Old May 10, 2019 | 09:15 AM
John89's Avatar
John89
Make sure you keep the drums on when you center them by pushing the brake pedal. Adjusting from the backing plate with the drums/wheels on takes a little technique. Sometimes you have to use a skinny screwdriver to push the locking tab away from the "star" adjuster and then rotate the "star" with the adjusting tool. (Funny looking pry bar type tool)
Old May 10, 2019 | 09:24 AM
Tedster9's Avatar
Tedster9
The brake shoes can be tightened with a single tool (screwdriver or "spoon") they aren't supposed to ever loosen on their own though, to loosen up the shoes a second tool is needed to move the ratchet out of the way of the star wheel.
Old May 10, 2019 | 12:31 PM
Arsoncop's Avatar
Arsoncop
So I need to have the brake pushed in order to adjust through the backing plate ?
Old May 10, 2019 | 01:06 PM
John89's Avatar
John89
No. Pushing the pedal just centers everything up inside the drum. Once you get them close by hand, you can use the self-adjusting process. Run it backwards about 10-15 feet and apply the brakes. Do this a few times and it should help.
Sometimes if the hardware is old or has a lot of miles on it, the self adjusting process doesn't always work.
Old May 10, 2019 | 02:10 PM
Tedster9's Avatar
Tedster9
The problem there, is self-adjusters only take up very small amounts of wear, as brake lining is removed over time, and even then it's only one click. If the linings are too loose at the start, at install, the self-adjusters will never work. I would cinch them up till they drag a bit, and take a test drive around the block and then check them again. Brake shoes used to be sold oversized (to better fit drums that had been turned) and then shaved on the arc machine to get a good full contact patch. It's a little tougher to get drum brakes to work right in one shot today.
97XLT4X4
20
Mar 5, 2011 12:04 PM
BigBadPowerstrok
Nov 13, 2007 01:32 AM
missalot
May 20, 2006 11:57 PM
trinogt
Dec 5, 2005 10:51 AM
Jason 88F150
Mar 25, 2002 07:51 PM
