Rear spring visual ID?
Old May 7, 2019 | 02:13 AM
RyanMac119's Avatar
RyanMac119
Originally Posted by pirate4x4_camo
and a AAA RV nembership
Your vote of confidence is overwhelming.
that said, we have AAA and a Good Sam membership. Good enough? 😂😂😂
Old May 7, 2019 | 07:28 AM
WE3ZS's Avatar
WE3ZS
Originally Posted by RyanMac119
My plans are simple. Towing the camper on family vacations, and to dog shows. I would like to build her to handle whatever towing job is thrown her way. Wife is looking to upgrade the camper, but no concrete decision has been made. I’m of the mentality that it’s better to have it and not need it..than to need it and not have it. So my thoughts were to build it to handle 15k or more, and that should cover anything “tag along” or non 5th wheel.
im not concerned with lifting. We have a Jeep for throwing money away in that department. 😂
WOW, I missed the planned for 15K trailer weight before! That is extremely heavy for our rigs.
Old May 7, 2019 | 10:16 AM
pirate4x4_camo's Avatar
pirate4x4_camo
FTE Remembers
15k is exceeding what every part was designed for by 50%
odds are high someting is going to fail leaving you stranded.
towing in general is hard on equipment, grossly exceeding design parameters rarely works out for long, that is the reality of it. i used to occasionally tow 14k with mine but it was taxing even though i built it to handle it, ended up buying a new dually truck for the task and after 100k of that realized even that was not good. now we use a semi truck. better to be at the low end of a vehicles rating then at the high end or in my case 40% over it.
that said, it can be done but just because doesnt mean you should.
Old May 7, 2019 | 12:13 PM
RyanMac119's Avatar
RyanMac119
Again, doubt I would ever pull 15k. I pulled that number out of the air. Essentially, I just want it built to handle whatever could be thrown at it. If I have a 7k TH, with 3k of “stuff” in it, I want to be able to pull that over mountain passes, without the Truck sending me death threats.
Old May 7, 2019 | 01:07 PM
pirate4x4_camo
FTE Remembers
fair enough,
the procomp 22210/22415 setup i outlined with air bags would be the setup I would suggest. the other things i just mentioned are all still items you will want to address.
Old May 7, 2019 | 03:04 PM
RyanMac119's Avatar
RyanMac119
billet torque converter, probably new steering gear
6.0 trans cooler is on my list, as well as 4.30 gears. Could you elaborate a bit on the billet converter and how it would help? This is the first I’ve seen it mentioned.
also, what does “stealing gear” consist of?
Also, as a side note, what would you consider a “first to address” issue? My plan has been to see how it drives and rides, then see how it does towing our current 7k camper, and go from there.
Old May 7, 2019 | 04:32 PM
WE3ZS's Avatar
WE3ZS
What size tires are are you planning to eventually run? If you ever think that larger than stock tire's are in the future and you are looking to drag a big heavy TH over mountains then you should look at even deeper gears than the 4.30s. Maybe even with stock 31.6" tires a deeper 4.56 would serve you better towing heavy over the big mountains, my EX with an effective 4.39 (4.88 gears and 35" tires) drops a gear on the steeper Eastern mountain grades at highway speed towing 12K.
Old May 8, 2019 | 04:42 AM
RyanMac119's Avatar
RyanMac119
I have no plans for larger tires. We all know that plans CAN change, but my only interest for the X is towing/family travel.
Now, when changing the gears I’m only changing the internals, or are we talking a whole new carrier?
Old May 8, 2019 | 06:21 AM
WE3ZS's Avatar
WE3ZS
Carriers will be fine, unless you want to change over to a different type of limited slip than the factory unit. New ring and pinion is basically what you would be installing. For a dedicated tow rig that will be dragging a heavy trailer over the big Western mountains I would look at 4.56 gears with stock sized tires.
Old May 16, 2019 | 07:48 PM
RyanMac119's Avatar
RyanMac119
Dropping off the X next week for new engine and 4.56 gear change(See also: upgrade?) should have it back after a few days.
I do appreciate all the advice and info. Once I get her back and put a few miles on it, I’ll post up how it “feels” both towing and not and if it’s not too much to ask, I would like to be educated a bit so I understand what does what, and can make better decisions going forward with upgrades.
Old May 16, 2019 | 11:00 PM
WE3ZS's Avatar
WE3ZS
"What does what" in regards to...........?
fordboy67
Oct 12, 2022 11:24 PM
DeathRangerofDeath
Mar 5, 2016 04:58 PM
ithaca1230
Feb 13, 2014 03:08 PM
Tylus
Jun 19, 2013 11:59 AM
jefxxo
Dec 17, 2004 08:55 PM
