New to this site Excursion question
Old May 4, 2019 | 11:17 PM
Robert Saucedo's Avatar
Robert Saucedo
I recently changed my IAC and now my EX is running like crap i checked all vac lines and everything seems to be ok any ideas. Thanks in advance
Old May 5, 2019 | 01:27 AM
'88 E-350's Avatar
'88 E-350
You should expand on what "running like crap" is.
Old May 5, 2019 | 03:15 AM
seville009's Avatar
seville009
If it was running better before the iac was changed, I’d start with that. Maybe the new one is bad or somehow installed wrong.
Old May 5, 2019 | 06:07 AM
Tbug05LTD's Avatar
Tbug05LTD
Robert what year is your Ex? Did you replace the gasket? What type of gasket did you use?
Old May 5, 2019 | 02:20 PM
Robert Saucedo
its idling hard and dont have much power that i used to have
Old May 9, 2019 | 07:16 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
If you reinstall the old IAC does it run better?
I'm thinking things like the old IAC died while in a position that supports a reasonable idle and the new one is fully open so it it allowing the engine to run lean all the time. Or something.
. . . which leads me to wonder if the plug and/or attached wire is damaged somehow, leading the old IAC to stop working and the new one to never start working.
Old May 9, 2019 | 08:42 PM
Jakerichards1's Avatar
Jakerichards1
Maf
Take a look at the intake on your truck and see if the mass airflow sensor grommet didn’t fall out the underside of the intake. I’ve had that happen before.
I ultimately put a zip tie around it to make sure it didn’t get bumped and fall out
It’s easy to check and it will make it run like crap instantly if that falls out
randinow
Jul 27, 2010 09:10 PM
johnny dangerous
Oct 27, 2007 10:07 PM
rews2
1978 - 1996 Big Bronco
Jul 14, 2005 09:21 AM
dr
Apr 13, 2004 09:38 PM
F250reddog
Jan 13, 2004 08:31 AM
