Oil filter is out and cap off. It really sounds like someone is blowing bubbles. I hear no clean air leaks in housing or fuel rails. I have had pressure on it for about 3 hours. Should i put back together and try and get some new readings. I did install new Dummy plugs and stand pipes. Checked sensers, all look good no leaks i can hear or see.
Bismic have question. I know i have late model 6.0 becouse i have my icp on passenger side valve cover. When i try to order a 2004.5 hpop thru differant DEISEL sites they keep showing my the new style hpops. Is there something i can give them to let them know witch motor i have. All my passenger side valve cover says 2004. Thanks as always.
Yeah, problem with that is diesel sites I'm dealing with online don't have phone numbers. Unless I call Ford Motor Company. Which I don't want to pay their prices. But as always good advise. Thanks Sean.
You could get the correct Ford Motorcraft part number and do it that way.
The better option I think is to call Ed and get it from them. That way if you
use the stock Ford part you also get the Warrantee and not some grey market
short one or none at all. Also you know that FICMrepair will stand behind the
part and help you.
