oil pan change
Old Apr 30, 2019 | 06:36 PM
Mich6.0's Avatar
Mich6.0
oil pan change
Is it possible to change the oil pan by jacking up the motor and blocking the mounts and pulling the turbo, or do you have to pull the cab.
Old Apr 30, 2019 | 06:41 PM
Motohead911's Avatar
Motohead911
Check out YouTube, Diesel Tech Ron, has a video on it. You can jack up the motor and R&R the oil pan.
Old Apr 30, 2019 | 06:44 PM
m-chan68's Avatar
m-chan68
The engine only needs to be jacked up about an inch or so. Pan removal is done by sliding it rearward once all the fasteners are removed, and then reaching inside to unbolt the oil pickup tube once there is sufficient access. The pan with the pickup tube unbolted can then be slid the rest of the way out. Cab or turbo removal is completely unnecessary.
Old Apr 30, 2019 | 07:08 PM
Mich6.0's Avatar
Mich6.0
thanks for the prompt reply's pan is showing some rust spots , want to stay ahead a possible leak.
Old May 1, 2019 | 02:09 AM
Euroman's Avatar
Euroman
Good info, mine has more than just a few rust spots
ford1183
Nov 28, 2012 04:52 PM
Lineman85
Oct 10, 2012 12:32 PM
szotty
18
Oct 23, 2010 11:23 AM
candrit
Jun 17, 2009 06:17 PM
kohlerjd110
18
Mar 5, 2005 08:10 AM
