Oil Pan Change
Old Jun 15, 2009 | 11:16 AM
candrit's Avatar
candrit
Oil Pan Change
My oil pan has rusted out and is leaking. Is there a way to change the oil pan without pulling the engine ?
Old Jun 15, 2009 | 11:26 AM
DieselCamper01's Avatar
DieselCamper01
I do not have a link but someone sells a two piece replacement pan. The only "approved" methon is pulling the engine. Depending on how badly it is rusted through you could try patching it. Either weld in some metal or put on an epoxy patch.
Old Jun 15, 2009 | 11:28 AM
redfire42's Avatar
redfire42
someone also mentioned about cuting out the crossmember to pull the pan and then welding it back in. Sounds more af a PITA but it could be an option.
Old Jun 15, 2009 | 11:37 AM
12ozd's Avatar
12ozd
Pretty sure you have to pull the engine / but , I thought I read on here a few days ago about someone pulling the trans.and getting the oil pan out that way.
Definately easier if it will work.
I'll post it if I can find it.
Old Jun 15, 2009 | 01:01 PM
Nick 99's Avatar
Nick 99
Try doing a search on the oil pan rust issue, I'm sure I read a thread about using an epoxy patch that worked well.
Nick
Old Jun 15, 2009 | 01:12 PM
Mike F250's Avatar
Mike F250
I had my local dealer replace mine under warranty. They said they pull the trans and bring the motor back far enough to pull the pan. I don't see why they would lie about it. They charge less than other dealers to do this method. Almost a year now and all is well.
Old Jun 15, 2009 | 01:27 PM
CSIPSD's Avatar
CSIPSD
Just pull the motor... Its not that hard to do. You have to flip it over and dry everything and let it sit overnight anyway. Do you really want to do it half assed and then do it again later...
Old Jun 15, 2009 | 05:03 PM
74baja's Avatar
74baja
I think it might have been Dan... or maybe someone else (one of the super-experts around here), who used a fuel tank patch kit to repair theirs. I'm sure they'll chime in soon.
Old Jun 15, 2009 | 06:05 PM
mjtpolice76's Avatar
mjtpolice76
I used expoxy on mine seems to be holding up ,fine.
Old Jun 15, 2009 | 06:18 PM
big poppa's Avatar
big poppa
Automator Dave had his replaced in a shop, ended up getting a bunch of other stuff done while they were in there. Pulling the motor would be my choice but whatever works for yaa, good luck..
Old Jun 15, 2009 | 06:22 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
If yours is rusted to the point where it's leaking through, the only way to properly fix it for good, is to put a new oil pan on, with the engine out, or upside down.
Old Jun 17, 2009 | 06:17 PM
candrit's Avatar
candrit
Thanks for the feedback
Thanks for all the feedback. I guess it's time to break out the wrenches and get at it.
