Transmission Issues
Old Apr 28, 2019 | 02:09 PM
dmacd's Avatar
dmacd
Transmission Issues
Hello new member here, looking for help. I have a 2013 E450 5.4 l with an automatic 180,000km or 110,000 miles. I had a PO751 shift solenoid A performance/ stuck off code pop up a week ago. The dealer didn't have the solenoid in stock so I erased the code and continued using the vehicle to see if it came back. 2 days 250 kms later the tranny slipped while accelerating from a stop sign and went into limp mode. I pulled over restarted engine and everything seemed fine again but it showed the same code. Next day after 4 hours of stop and go driving it slipped again accelerating from a stop sign but this time it wont move in any gear. Towed it home and it shows the PO751 code as pending and nothing else. I have line pressure at the test port, it bounces a bit but there is pressure in all gears no chunks in the pan or filter though the filter was dirty . Any suggestions on what the problem may be or what my next step should be would be greatly appreciated.
Old Apr 28, 2019 | 04:00 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
My guess would be a stuck shift solenoid A.
Old Apr 28, 2019 | 04:33 PM
dmacd's Avatar
dmacd
would that result in losing all gears? I only ask because my only experience with transmissions is a few RE and RE 's and a couple shift kits 30 years ago. when I went to order the solenoid I was told even if it failed I would have reverse and one forward gear left. Mind you that was from a parts guy and one awfully young looking Tech, no one with your experience. Thanks for replying
Old Apr 28, 2019 | 06:05 PM
Mark Kovalsky
I don't know that transmission is in your van so I can't answer that.
ryanb898
Jun 9, 2017 09:07 AM
Scott Wallace
1997 - 2003 F150
Dec 28, 2016 08:02 AM
Greek 350
Mar 15, 2012 08:02 PM
steverowe
Mar 5, 2004 03:56 PM
PMD66
Apr 13, 2003 09:45 AM
