Transmission Question Shift Malfunction 4r100
Old Jun 5, 2017 | 02:31 PM
ryanb898's Avatar
ryanb898
Hi everyone, glad to be apart of this site since i always stumble here from google i figured id sign up.. a quick history on my truck.. i bought it 4 years ago with 205K, swapped trans fluid.. 10k miles later ( i dont drive it alot ) im throwing the code P0750 Shift A malfunction.. i figured id swap the solenoid pack since im pretty handy and it was affordable.. but it didnt seem to do the trick.. it drove around the block good for 5 minutes before it started shifting weird and throwing a code again.. almost seems to be slipping... I still have to check fluid level again and scan the code again but any suggestions? I have an apt to go to the tranny shop this week and would like to avoid the big bucks if possible.
Old Jun 5, 2017 | 02:48 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The only way that code can set is if shift solenoid A is stuck. Did you clear the codes when you replaced the solenoid body?
Old Jun 5, 2017 | 03:03 PM
ryanb898's Avatar
ryanb898
well i disconnected both batteries for a few minutes.. is that sufficient.. and im glad to get your input on this i see you comment on everyones posts you legend! haha
Old Jun 5, 2017 | 05:24 PM
ryanb898's Avatar
ryanb898
a friend just scanned it and said the code was stored in memory for p0750.. he cleared it.. havent tested it yet but did the pcm assume the new one to be the original broken one due to code in memory?
Old Jun 5, 2017 | 08:49 PM
Mark Kovalsky
If the code was not cleared the PCM doesn't know there is a new solenoid.
Old Jun 6, 2017 | 08:56 AM
ryanb898's Avatar
ryanb898
Okay, Im going to check fluid level tonight and give it another test run since my friend cleared the code in memory... i was under the impression i could clear the code without a scanner? My srt-4 used to clear codes with a battery disconnect, is that not the case for these diesel trucks mark? Thanks for your help!
Old Jun 6, 2017 | 08:59 PM
Mark Kovalsky
Sometimes they do, sometimes the batteries have to be disconnected for quite a while to clear the codes.
Old Jun 8, 2017 | 08:48 AM
ryanb898's Avatar
ryanb898
Yep didnt work, cleared the code as well... it drives fine for the first few shifts then seems to act up after a couple minutes of driving.. it seems to start with not wanting to shift up past 2nd.. then it sometimes will, or sometimes bounces back down a gear or feels like its slipping... then comes the OD flashing.. i replaced the solenoid because the only code it had was P0750.. so im not sure why this hasnt resolved it I read something about the pcm being screwed up.. i have an aftermarket DP pcm in there if i remember correctly.. do you think i should pick up a stock for hahas? I wanted to avoid the shop but i believe its going there this weekend.. i need it bad to do repairs at my house... thanks for the help mark
Old Jun 8, 2017 | 09:33 AM
Mark Kovalsky
What are you using to read codes? If it isn't the right tool there may be other codes that you can't see that would help with this.
Old Jun 8, 2017 | 10:16 AM
ryanb898's Avatar
ryanb898
It was a snap on solus.. for some reason my previous message didnt post.. is that scanner sufficient?
Old Jun 8, 2017 | 01:17 PM
Mark Kovalsky
I'm not sure. Maybe someone else knows?
My guess is that it isn't sufficient. If it won't shift there should be codes set for the missing shift. Those codes can't be read by most scan tools.
Old Jun 8, 2017 | 04:58 PM
ryanb898's Avatar
ryanb898
good point I'll have to look that up... I've never seen this before. Last I drove it after a 30 minute disconnect it acted up and threw a code now today I fire it up and nothing its driving normal no flashing -_- is it possible it learned there's a new part there or? Also I'm curious, could the shift lever wires be issue? I haven't checked them in some time.. thanks
also mark I used this part to replace.. is it correct?
dorman 609-023
i have a 99 f350 build date 6/99
Old Jun 8, 2017 | 08:40 PM
Mark Kovalsky
It doesn't learn that. The part attached either works or it doesn't work.
Worst case all that the shift lever wires could do is keep it from shifting to fourth gear. [/quote]
dorman 609-023
I believe that is the right solenoid body. The shift solenoids are the same on all the 4R100 solenoid bodies, only the torque converter clutch control solenoid is different on the '99s built before January 1999.
Old Jun 9, 2017 | 06:42 AM
Walleye Hunter's Avatar
Walleye Hunter
I have one of those models and the tranny has been swapped out for a rebuilt one. What is the relevance/importance of that clutch control solenoid? Are they a plug and play swap or is there more to it than that?
And thanks for the help!
Old Jun 9, 2017 | 09:07 AM
Mark Kovalsky
That's the solenoid that locks and unlocks the clutch inside the torque converter. If you have a mismatched solenoid to the hardware in your transmission when the torque converter clutch is engaged it is going to SLAM on.
tarditim
Oct 12, 2011 03:29 PM
frnkln2003
Feb 10, 2008 08:43 AM
METERGUY56
Mar 3, 2007 07:31 PM
steverowe
Mar 5, 2004 03:56 PM
fjones
Jul 10, 2002 08:06 PM
