I'm new to this site and this is my first post besides my New member "howdy" post. I have a 2000 F-350 DRW w/194K and trouble code 1746. My scanner says it's a solenoid error and I would like to confirm if this is the most likely cause and/or if there is another culprit in the mix.
I've tried to research the posts for this particular code without any luck. I only recently purchased this truck and it seems to shift hard, esp from 1st to 2nd but since I haven't had it long, I don't know whats "normal" for this truck. It also seems to shift too quickly from 3rd to 4th.
Thanks Mark. I was looking at transmission posts and hoping you would weigh-in. How do I narrow it down? I'm assuming at this point that it is the solenoid pack but how would I confirm or eliminate it?
Check the wiring between the PCM and the trans for open, short to ground and short to power. Check the solenoid across it's two pins. I forget the resistance, I think it is around 4 ohms, but it has been many years since I last looked up that value.
