Code P0761 - shift solenoid C
Old Mar 4, 2004 | 09:12 PM
steverowe's Avatar
steverowe
Question Code P0761 - shift solenoid C
My '98 Explorer had this code, which prompted me to take it to a transmission shop. I picked it up this evening and before I got a couple of miles I noticed the check engine light was on. Just in case the shop hadn't cleared the code, I stopped at a parts store, pulled it and had P0761 again. I cleared the code and before I got home the O/D light started flashing, which it had done before I had the trans worked on.
The transmission shop had changed the "shift solenoid" and "TCC solenoid". Now what?
Thanks.
Old Mar 5, 2004 | 03:56 PM
Casey's Avatar
Casey
Most likely you have a problem with the wiring or a connector to shift solenoid C. The code does not mean the solenoid is bad, it means something in the circuit is bad. That can be a wire, a connector, or the solenoid.
TenHoles
Feb 23, 2025 06:33 PM
Brian Mansour
15
Aug 16, 2019 06:28 PM
AlaskanEx
Mar 24, 2011 02:54 AM
jrlowscot
1997 - 2003 F150
Aug 21, 2006 11:25 PM
gabebdog1
1983 - 2012 Ranger & B-Series
Nov 17, 2005 12:43 AM
