2011 6.2 Diff Fluid Change Questions
Old Apr 24, 2019 | 02:00 PM
Wandering Dixie's Avatar
Wandering Dixie
I’m planning on changing my diff fluid in the front and rear for the first time tomorrow. Just wanted to confirm a few things before I do. I believe the front axle is a Dana 60 and the rear is a Sterling 10.5. Front uses 80W-90 and the rear uses 75W-140. I assume Mobil 1 synthetic is fine in both? The rear has an factory e-locker. Is there an additive that I need to use for it? What’s the torq spec on the cover? Is brake cleaner ok the spray inside the gears to clean everything out of there?
Old Jul 12, 2019 | 01:43 PM
David Karpinski II's Avatar
David Karpinski II
Dear Wandering Dixie,
E-lockers and pneumatic lockers don't require friction modifier. The diff cover torque specs I believe is 23-35 ft/lbs. Good Luck!
90limited
Dec 2, 2018 08:56 AM
r-kid
Apr 27, 2013 07:34 PM
Quick444
Nov 3, 2009 04:15 AM
cowslinger64
1997 - 2003 F150
21
Jun 23, 2009 11:56 PM
wreedZ71
2004 - 2008 F150
Apr 19, 2009 11:07 AM
