Rear Diff Fluid Change
Old Oct 31, 2009 | 03:32 PM
Quick444's Avatar
Quick444
Thinking about changing my rear diff fluid since she seems to "thunk" louder than usual when I turn left and right sharply.
I know that I will need friction modifier but how much and what fluid should I be using? If I change the front axle, I don't need modifier up there right?
Thanks guys.
I woke up this morning and found out I have a day off!
Old Oct 31, 2009 | 03:49 PM
tdpower's Avatar
tdpower
Guzzle has write-ups on the front and the rear oil changes: Welcome to guzzle's Rear Differential Maintenance Web Page. It pretty much explains it all.
Old Oct 31, 2009 | 04:02 PM
hucka1a's Avatar
hucka1a
Good job Grant.
Old Oct 31, 2009 | 04:07 PM
Quick444's Avatar
Quick444
Thanks for that, I am an idiot. I have that link but I didn't even check.
Do I have a 10.5 rear and a Dana 60 front?
Old Oct 31, 2009 | 04:11 PM
Izzy351's Avatar
Izzy351
Yes and yes.... 75w-140 in the rear (most have FM in it already), and supposedly the same up front. When I asked the dealer, they said 75w-140 up front, but when I asked why, they said because Motorcraft quit making 75w-90. I would think whichever would work. Up there in the frozen north, I'd be tempted to run the lighter fluid...
Old Oct 31, 2009 | 07:00 PM
big poppa's Avatar
big poppa
They sell the friction modifier at the dealer for about 5.00 for 4oz I believe, even if the new fluid has it in it already, mine needed a little bit more, Royal Purple 75-140 syn(F-M added) user here.
Old Nov 1, 2009 | 02:11 PM
Quick444's Avatar
Quick444
Thanks for all the information guys. Next time I get down to the "big" town of Wasilla I will try to pick up all the right stuff.
Old Nov 1, 2009 | 03:58 PM
STROKIN'IT7.3's Avatar
STROKIN'IT7.3
If it's an 01, its Dana 50 correct? My understanding is 02 and up had 60's.
Old Nov 2, 2009 | 07:58 AM
SGnAZ's Avatar
SGnAZ
Correct
Old Nov 2, 2009 | 08:38 AM
PlatinumPete's Avatar
PlatinumPete
I went with the Mobil 1 syn. 75-140 in the rear and 75-90 in the front. It has the FM in it also and it worked out great, zero chatter now matter how tight I turn and instant posi every time.
Old Nov 2, 2009 | 08:48 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
My '01 has the Dana-60 up front. It may be because of it being a dually.
Old Nov 2, 2009 | 09:11 AM
PlatinumPete
This is something I've been trying to figure out too. My 01 came with a D50 according to the build sheet but, doesn't the D50 have 30 spline axle's? When I changed my hubs, the guy got me hubs for the 35 spline D60. I didn't realize it til I had the old ones off and when I counted, I found that I do indeed have 35 spline axles........? Any thoughts?
Old Nov 3, 2009 | 04:15 AM
UNTAMND's Avatar
UNTAMND
I had thought the F250s had the Dana 50 front until 02-03 and all the F350s had the Dana 60 front.
I was also curious if the front had hypoid grease instead of either 75-90 or 75-140. My diff tag is gone so I'm curious also. Ill probly use whatever synthetic is on the shelf anyway. Maine is not cold enough to need a debate on the lighter or heavier fluid.
While you have the diff cover off though, remember to check seals and bearings as well as make sure your vent tube is not plugged and long enough to be above the top of the tire.
rtazz17
41
Jul 1, 2011 04:20 AM
Rob.D
Aug 4, 2008 09:21 AM
ckal704
Jun 25, 2007 03:11 PM
electrk
Jan 22, 2007 02:21 PM
