recommendation for small business van + towing
I'm a small business owner and looking for a van that I can use to haul material/deliver product for my business as well as haul an open car trailer +3200lb fox mustang to the race track. $3,500 is budget im comfortable with ATM. Here in Seattle nobody's letting the post 2002 (mod motor) vans go cheap it seems like. e250 seems right for my needs. The 5.4's scare me a bit, anything e350 seems overkill and are too compicated/ expensive for me to fix. 90's e250's are more in my budget, but they seem run down at that price range. I like to hunt for good deals, but I'm wondering what my general expectations should be, and what might best suit my needs while I continue researching and looking.
Those are my general assumptions. What are your thoughts? Am i on the right track with the 90's e250? If so, do I look for 5.8? is there anything in particular I should be looking fr while browsing craigslist/apps? Thanks ahead of time.
I had a 2003 e250 with the v6. It has all the cargo space you need, AND it pulled an open trailer with a race car heavier than yours.
Everbody hates the 4.2 v6, so you should be able to get E250 v6 pretty cheap. The 4.2 is a wimpy dog for sure, but it got the job done.
With all that said; if the 4.2 will do it, then certainly a 4.6 or 5.4 will work also.
The 5.4L has more horsepower and more torque than the 5.8L, but at higher rpm. If you let it wind up it will tow more weight better than a 5.8L. But the 5.8L is stronger up to about 2500 - 3000 rpm, so seat-of-the-pants it feels better to us old-school truck guys.
We have a respected member on here that has towed heavy with the extended body and he says it’s no issue.
The 5.4 is definitely happier when spinning more than I think it should.
Would probably be happier with a 4.10 or 4.56 gear in it with a trailer behind it.
I usually just lock it in 3rd for anything under 70 when loaded/towing.
Same with the V10 in my Excursion. Those should all come from Ford with a 4.30 gear. A bit of a slug with 3.73.
williet34
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
19
03-08-2018 10:25 PM
bob1987f
01-22-2007 06:54 PM
beagledog
10-21-2005 09:03 AM
