neutral safety switch???
Old Apr 19, 2019 | 01:59 PM
xbarstar's Avatar
xbarstar
4wd Low
is this not where my neutral safety switch should be on my f 350 ???
Old Apr 20, 2019 | 04:16 AM
Yahiko's Avatar
Yahiko
FTE Remembers
Nope. The 5R110W does not have one like you think it should. It has a device that tells the PCM (See page 29-3 of the PDF)
what gear it's in and it not a normal switch that you can jumper. I have a discription somewhere. Maybe one of the other members
will post before I can dig it up.
File Type: pdf
File Type: pdf
Old Apr 20, 2019 | 06:53 AM
87crewdually's Avatar
87crewdually
It is a range sensor and is inside the transmission. You have to drop the pan to get to it.
Old Apr 20, 2019 | 09:31 AM
xbarstar's Avatar
xbarstar
4wd Low
I may be in over my head checking that. i have never opened a transmission before :-(
Old Apr 20, 2019 | 12:23 PM
Euroman's Avatar
Euroman
If it's a plug-in module you'll be ok. Just be prepared to get dripped on.
Old Apr 20, 2019 | 04:26 PM
Yahiko's Avatar
Yahiko
FTE Remembers
I have got to quit posting when I am tired.
I forgot to ask what is going on that makes you think it bad?
Old Apr 20, 2019 | 05:09 PM
xbarstar's Avatar
xbarstar
4wd Low
THANK YOU ALL!!!
I GOT IT Thanks folks
Jeff64F100CrewCab
Aug 4, 2019 01:47 PM
gapman789
Nov 23, 2018 05:18 PM
senix
All Things Towing
Dec 16, 2017 07:15 AM
petrokiller
May 21, 2016 10:24 PM
Blown 331
Sep 26, 2010 09:49 PM
