My new (to me) truck has a touch screen system with back-up camera, similar to what I am used to in my 2016 Lincoln MKC. However I have the 120VAC power plugs on the passenger side of the dash, and the rear console where a USB port normally is (from what I saw in other classified pictures when I was shopping). I can't find a USB port anywhere to plug in my phone for charging. Then I discovered the top of the dash opens to what appears to be another storage area, with multi-media connections....A/V, USB and SD slot, and there is a an SD card in it that has the Ford Synch logo on it. So....
*Is that Ford Synch SD card needed for the system to work, or can I put my own SD card in there to act as a storage device for all my music?
*Is there a USB port hiding somewhere that I can use to charge my phone, without having a cord exposed out of the top of the dash? That seems silly to me over having one in the actual console.
I know I could get a cheap 12volt port to USB adaptor or 120vac plug to USB, but really just want to hide a cord in my console without having adaptors exposed.
Some background info on you truck would be helpful (Year and trim)
Sounds like you have a Sync 2 system. The SD card on top is for Navigation. Music will not play through it. You can plug a USB stick into one of the slots with music and it will play. There are no other USB ports other than the ones you describe on top of the dash.
Everything you describe is Sync 2 MFT. You will have to add your own USB ports as many of us have. You can get the 3.0 USB charger and replace the unused 12v socket with it.
I use a 120v AC charger plugged into the center stack 120V AC plug. Otherwise you will need a 12v DC charger or 12v DC to USB adapter. Make sure the 12v DC adapters have the proper amp ratings for your phone. My Samsung Note 8 requires a 2.1a or higher rated charger/USB adapter.
I've searched here and youtube to no avail....is it a simple process to remove one of the 12v power outlets on the center stack and put a USB port in it's place? I found a USB port that looks to be a universal fit, that gets hardwired to +/-. I'm thinking it should fit in where the cigar lighter port is now, just curious if I am on the right track and an easy removal.
And disregard! Finally found this on youtube: link removed...Looks pretty simple!
This radio setup for the 2011-2012 trucks. The 2013 thru 2016 is a "component" setup. It is pieces and not self contained. you could probably get the lower right cubbie hole plate with the usb port in it but would be cheaper to just get one from Wal Mart that plugs into the lighter if all you are going to do is charge your phone/tablet.
I actually just want to pop out the lower left bezel where the trans brake button is, and the 12v and replace it with a Dual USB port. I also want to pop that entire dash bezel out so I can hide my GPS tracker behind the radio. I'm not trying to change anything about the head-unit or the Synch system. I'll load a USB stick with music and stick it up in the top media hub....combined with Sirius and bluetooth from my ipod I should have more music options than I'll ever need.
. The cover on the passenger side lighter socket closes over this thing so you don't know it's there.
There's also a lighter socket in the storage compartment of the center console. To facilitate running a USB cable out of the center console Ford put a little dip in the lower portion of the front of the console on the passenger's side. I bought 3 of those USB chargers. Put one in the console, one in the passenger's side lighter socket and one in the drivers side socket. Before I upgraded to Sync 3 I had a USB cable plugged into it at all times. When I put Sync 3 in I ran a USB cable from the top center storage area on top of the dash behind the center stack cover out where the center stack cover meets the lower dash cover.
The SD card contains the maps for your NAV system. The letter / number combination on the card tells you what year the maps are from. I believe A10 is the 2019 version.
