Ford Transmissions
Old Apr 13, 2019 | 09:04 AM
portagoosey's Avatar
portagoosey
Ford Transmissions
I have two 68 Ford truck transmissions. The one in my work truck has the aluminum tower and is noisy and the other one I want to install in it has the cast iron tower with the screw on shifter cap. I noticed that the tail shafts are different lengths and the cast iron trans has a bigger driveshaft. What model trans are these two and can I swap the cast iron one to my truck without too much trouble? thanks.
Old Apr 13, 2019 | 10:20 AM
FuzzFace2's Avatar
FuzzFace2
Think we are going to need a little more information.
Are both trucks 68's?
What models are they?
Do you have the numbers off the door tag?
Are they both 4 sp with granny lows?
What motors are in the trucks?
You say the tail shafts have different lengths are they both slip or bolted yokes?
Any numbers on the side of the 2 tranys?
How about PTO covers 1 or 2 and on what sides and remember left & right is when sitting in the drivers seat.
Dave ----
Old Apr 13, 2019 | 10:54 AM
RichS2659's Avatar
RichS2659
You have a choice of two 4 speeds available: The Borg-Warner T-18 and the New Process NP-435.
The T-18 will have B-W casting marks and will have either T-98 or T-18 cast into the top cover. Reverse will be right and up.
The NP-435 will have N-P casting marks and reverse will be right and down.
Here you go for ID:
Manual Transmission Identification Guide - FORDification.com
Old Apr 13, 2019 | 11:05 AM
FuzzFace2's Avatar
FuzzFace2
Here you go for ID:
Unless someone replaced the T18 with a newer one and reverse is also right & down as the shifter almost hits the seat in my 81 F100.
Dave ----
Old Apr 13, 2019 | 02:48 PM
portagoosey
Thanks for getting back to me. Fuzzface2, both trucks are 68 F250's. Both are the the truck 4 speeds with granny low. don't know about the yokes yet as i haven't got them out yet. My truck I'm putting the tranny in has the 300 cu. in. six and it is a NP-435. The truck with the other good tranny is the cast iron top cover T-18 according to one response I've had already and the engine is a 390 V-8.
Old Apr 13, 2019 | 02:58 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The one in my work truck has the aluminum tower and is noisy and the other one I want to install in it has the cast iron tower with the 8MTH-7220 Warner T-18 screw on shifter cap.
The other is the New Process 435 4 Speed. Its shift lever retainer cap (B8T-7220-B) has two notches, it's retained to the tower with two pins.
To remove this spring loaded cap, it must be pressed down by hand and held down while turning it counterclockwise to remove it.
People unaware use pliers or channel locks to remove it, which tears out one or both of the notches. Not pleasant!
Old Apr 20, 2019 | 10:11 AM
portagoosey
Hi all, an update on my transmission project on my 68 F250 with a 300 cu.in. six in it. It had a noisy NP435 in it and I'm installing a T-18 good used unit in it. Turns out, it's a straight across swap. The case is longer on the T-18 but the tail housing is shorter so it's the same length, so it'll bolt right in. The rear yoke swaps but wasn't needed as the u joints are the same also. I live here in the foothills of California so my truck will see temps ranging from 20 to 110 so what would be a good trans oil to put in it?
Old Apr 21, 2019 | 02:39 AM
GaryKip's Avatar
GaryKip
A synthenic 75W90 works in the NP435, But I'm not sure about the T-18.
Dr. Dirt
31
Nov 17, 2021 09:35 PM
CantAffordAToyota
73
Dec 4, 2016 10:56 PM
Joeseph
Jan 25, 2011 01:09 AM
msteelsos
Jan 28, 2008 10:01 PM
TigerDan
Aug 9, 2004 07:23 PM
