High idle hours?
Old Apr 12, 2019 | 05:56 PM
  #31
mtnguy's Avatar
mtnguy
On our 2017 F350 with the 6.7, if the ignition is on in the accessory mode, the engine hours is counting as observed in the trip 1 or 2 display. Is that supposed to record that in accessory mode, and does that count as idle engine hours even though the engine is off ??
We have about 20% idle engines hours compared to the total engine hours, and I think that is high. We take long trips, with very little idling. I idle on a cold start up for a couple of minutes before taking off, and idle at shutdown just enough for my engine oil temperature to get down to about 198 degrees to let the turbos cool down, and that is it.
Old Apr 12, 2019 | 06:09 PM
  #32
kper05's Avatar
kper05
My understanding that screen is simply key on time (including accessory) and not the engine hours counter. Or is it labeled engine hours? I have the basic 2011 screen so it only tracks miles since reset so uncertain of the wording. My Fusion just shows the time within the trip screen without a label.
Old Apr 13, 2019 | 07:55 AM
  #33
senix's Avatar
senix
here is mine for a comparison
Old Apr 13, 2019 | 07:58 AM
  #34
Magnolia Tom's Avatar
Magnolia Tom
Wow! You must not have any stop signs or lights where you live 😀
Old Apr 13, 2019 | 08:01 AM
  #35
senix's Avatar
senix
Average speed is 35 mph. I little lower with this truck then with others in the past.
I have slowed down I guess.
Old Apr 13, 2019 | 08:28 AM
  #36
Overkill2's Avatar
Overkill2
I watch the EGT1 and if it's over 400, I let it get below that before I shut it down. It's usually not because there is a down side hill that I hit right before my house and I use the engine brake on the way down. So that usually has EGT1 under 400 when I pull in the driveway. I was told it's better for the turbo and the oil.
Old Apr 13, 2019 | 08:48 AM
  #37
Chuck-B's Avatar
Chuck-B
6.7 Weight Loss
I'm not totally sure we hijacked Tom's thread, I think we are discussing his question of "is 38.2% idle hours too high". We talked about what percentage is bad, I'm not sure we've come to a consensus on what is "bad" maybe we did at 15 - 20% . We went down the rat hole of "is idling really bad", think we came up with it's a trade off between starter and battery wear vs. emissions issues and cylinder wall washing. Then we went into then we went into what others have. I think we've seen most of us are below the 38.2% that the truck Tom is looking at is. I'm at 26.7%, guess I should try and get that down a bit if 15 - 20% is "bad".
I'm not sure personally 38.2% would stop me from buying the truck, there are quite a few other things that I would also go into that decision, certainly a factor. Not sure what percentage would stop me from buying, maybe 50% or more. Usually "fleet" vehicles are very well maintained.
From what I've read, idle hours are increased when the truck is sitting there in park running, they are not increased when sitting in traffic (unless you put it in park) or sitting at a traffic light.
Old Apr 13, 2019 | 08:52 AM
  #38
Magnolia Tom
Thanks Chuck
I'm not going to write it off yet. I've looked at a couple other trucks around town and it seems like they are all over 30% idle time. Probably has to do with all the traffic around here lol
Old Apr 13, 2019 | 10:09 AM
  #39
dirthawg's Avatar
dirthawg
I would like to prove this theory myself because I don't think my truck would have as many idle hours on it if the counter only ticked away while in park. If that really is the case then I can beat the system by placing the transmission in drive with my foot on the brake while I fill out my paperwork at the job site.
Does anyone know if we can track engine hours and/or idle hours with ForScan or a monitoring app like Torque Pro? I feel the counter in the productivity screen would not be very accurate since there is no noticeable change until another hour is clocked.
Old Apr 13, 2019 | 10:31 AM
  #40
Ian123's Avatar
Ian123
The other thing people aren't mentioning is that cylinder washing not only occurs when idling, but also when your engine is not fully warmed up and the rings can't make a good seal. By idling the engine, you are keeping it up to temperature, instead of always letting it cool down and having to restart and warm it back up again.
In my experience, you get a LOT more fuel dilution by driving a bunch of short trips (engine always cold) than you do by a little extra idling...
Old Apr 13, 2019 | 10:39 AM
  #41
RIPbiker13's Avatar
RIPbiker13
I'm wondering his as well. I've gone up 2 hours in the past month and have not sat at idle in park for more than a few minutes total that I can think of. Most trips are on the longer side, at 20+ miles for a short run.
Old Apr 13, 2019 | 11:17 AM
  #42
kper05's Avatar
kper05
It's absolutely tracking idle time while in gear. I know my truck has not idled anywhere close to 27,060 miles worth in park. What I don't know is what RPM and/or speed is outside the idle time parameters. I think RPM can be eliminated because SEIC is idle time.
On another note, this causes me to realize how many dollars are into idling using Ford's 33 miles per 1 hour. Ouch, lol.
Old Apr 13, 2019 | 01:55 PM
  #43
Overkill2's Avatar
Overkill2
Thanks for pointing out the obvious, Chuck...
I agree with Chuck. As long as the maintenance of the truck was there and it was taken care of. I'd like some warranty extension though just in case.
Originally Posted by Magnolia Tom
Thanks Chuck
It has to be because no way has my truck idled that many hours in park. Stoplights, traffic and car washes in the winter has to be included. Good luck with your decision.
No doubt stationary while in gear in traffic has to be included in there.
Yeah right!
Old Apr 13, 2019 | 02:00 PM
  #44
RIPbiker13's Avatar
RIPbiker13
What if the DPF fell off? Would idle hours matter then?
#exhaustleak
Old Apr 13, 2019 | 02:03 PM
  #45
Overkill2's Avatar
Overkill2
#exhaustleak
Probably not...
"Breakin the law...Breakin the law!"
