2004 f150 cam sensor code and rough idle help?!
Old Apr 14, 2019 | 09:35 AM
redfishtd's Avatar
redfishtd
You do not have to reset codes
With good drive cycles they will go away . Lifting a battery terminal for ten minutes or so will clear them . Or you can have auto zone check them and clear them .
The other best thing you can do is change the oil often ,its the carbon from combustion clogging up this engine causing problems . I run marvel mystery oil 1 quart all the time as a slow cleaner , Every other oil change I do a engine flush but I have cleaned it out when I did timing job . Don't go over 5k or 3 months between oil changes ,there are too many screens and samll passages in this engine .Use mc filters as it has good drain back valve ,they are cheap at wally world .
Old May 9, 2019 | 04:38 PM
Tate Langel's Avatar
Tate Langel
Can phaser lockout?
So I went to the ford dealer to get an estimate kind of for kicks and giggles on a full timing job. What I found interesting is that the service guy recommended looking into a cam phaser lockout kit which he said would be about 1400 to install. Does anyone have any knowledge of these kits and or recommendations whether or not to do this?
I also asked him to give me an estimate for a full timing job including phasers, tensioners, guides, chains, seals, etc.. the quote was right around 2400. Does this seem reasonable?
Also asked him about putting in a melling 360hv oil pump and he told me that they can do that and that it is a good idea although they have to take the whole engine out to replace the oil pump! I am not sure why they do this as everywhere I have seen it is completely doable without this step.
Any advice would be great! Thanks!
Old May 9, 2019 | 06:20 PM
redfishtd's Avatar
redfishtd
It is 4wd so dropping oil pan is a little harder but nowhere near pulling engine . The oil pu tube screen needs to be cleaned when you have it off doing pump . Two little scews hold oil pu to oil pump with an oring gasket . Putting oil pump on crank is easy but do it carefully lined up properly . .Once the timing cover is off its a matter of setting up the timing point before pulling chains . The pump is right there 4-5 small bolts . You have oil pan off so its pretty easy . . You will be putting 2 little new gears on crank anyway for new chains ..Not moving crank after chains off is key at this point if you had timing points set up its a matter of putting new phasers on and new tensioners and lining up the dots and marked points on chains . Not much is required in special tools its just a time eater and brain work to get it right . . Anyone can do it if they study it and triple check it ..
There is more than one way to do it for sure . There are some hard points to get timing cover off but its just hard work a little trick here and there . It is nice to have the toothed holding tool to hold phaserr to take it off and re install but they are cheap on ebay . And of course you have to have a torque wrench ..
The parts for a full timing job including rollers and lashs all runs about $1400.
Old May 9, 2019 | 10:01 PM
3Prcntr's Avatar
3Prcntr
If the mechanic includes the rest of the timing and lash components with the lockout, ask him which parts and to show you the part numbers - then go home and look them up. Confirm with the parts FTMUL recommends. If they are anything else, no go. My guess is that with labor, they want to charge you $1400 for just the lockouts... not even close to worth it, and willing to bet when they get in there they will notice more and recommend a full timing job. If he did the lockouts and full timing job with new phasers as well as lash components and anything else for under $1600, I would be surprised. And then I would question the parts used.
Old May 10, 2019 | 12:10 PM
F150Torqued's Avatar
F150Torqued
A Ford Dealer mechanic that told me you have to 'take the whole engine out' to change the oil pump would not TOUCH my Truck under any circumstances for any amount of money. He either don't know his A$$ from ''Two Hot Rocks', or is a liar about mechanical technique (and probably prices/or both) - in either of which cases he's BANNED in my books.
Old May 10, 2019 | 08:07 PM
redfishtd's Avatar
redfishtd
The lockout and tune usually runs $700 ,save your money and put it in real engine oem parts . They fix nothing . Dealers service reps are money makers they pump up the business and get a share . There are some good ones but not many today ,the managers push them very hard and change them out. They are not your friend no more than an insurance adjuster is ..
The trick is to find a mechanic with a very good rep .
Of course us die hards do our own work . We can take more time and address other things rather than slap it together. The more you do the more you learn about all vehicles . Knowing the trouble turbos cause made me wise enough to reject the eco boost engine on my wifes 2015 explorer .And thank goodness we never got into ford double clutch transmission .
I'm also glad i'm not a boeing 737 max pilot . Engineers are not the problem the management is .
Old May 28, 2019 | 07:15 PM
Tate Langel
Update and thanks!
Thanks everyone for the great advice and info!
I just talked to a mechanic on the phone that many people recommended to me. He used to be a mechanic at the ford dealer and has done a ton of these timing jobs and now has his own shop. It was nice to be able to talk to someone near my area that actually knows something about these engines and that knows the answers to my questions! He is going to write me up a quote to do all the timing with oem parts as he recommended and get back to me tomorrow. I asked him about putting the oil pump in and he said that no one has had him do that yet but that he absolutely could. I’ll let everyone know what the quote is when I get it and if I’m going to go ahead with it.
I assume it is still a good idea to put a melling 360 hv pump in while he’s at it right? Anything else that should be changed for preventative maintenance?
Thanks.
Old May 29, 2019 | 03:29 AM
redfishtd's Avatar
redfishtd
If I go back in it will get the melling 360hv
Now after 60k on timing job I had put melling 360 in as the hv wasn't out yet . Its a no brainer very easy once timing cover off . Just don't force it on ,it takes a little wiggling to get it seated before putting bolts in .
There are not a lot of special tools required to do the timing job if you know the engine , Its a parts eater and they are expensive. You don't dare to use aftermarket except oil pump. Its a high labor job not easy to make a short cut . So you can't charge high hours and get it done in a third of book time . That's why shops don't like them . Nor can you use cheap parts as your call backs will eat you up .
Old May 29, 2019 | 03:46 PM
Todd D,'s Avatar
Todd D,
Maluk
Originally Posted by redfishtd
Do your self a favor list your miles and location on your profile > better yet put all mods and info on your signature so we don't have to look . We tailor our stuff by exposure to salt- extreme cold/heat etc . Mods ,4wd ,maint and miles info very important . Sometimes a local guy may offer to swing by or have some extra parts .No we don't want your address ,you can pm that to who ever you trust . You picked a good point to start at VCTS ,you will need seals with that . They are tough and not reusable
You are wise not to just shoot the messenger and replace sensors . Timing degradation is a matter of luck and maint no perfect answer .But warning do not use aftermarket phasers they will not work long .
Look at ford tech malukoco youtube he has great videos and he's sharp .
Maluko has helped me on my 04 lots and you can messing him through FB
Old May 30, 2019 | 09:49 AM
Tate Langel
I got a quote from the mechanic, 2,249 dollars including all oem parts, oil, coolant, etc. I am replacing all the timing and putting the new melling oil pump in. His price seems very fair to me. He charges 80 an hour which I was happy with as well!
Old May 30, 2019 | 03:59 PM
70f100longbed's Avatar
70f100longbed
That sounds like a good price using OEM parts. Just the parts alone is close to 1k. Like redfish said it ain't cheap to fix one of these right.
Dante827
Aug 18, 2017 07:00 AM
Thunder_pipes66
Jul 27, 2017 07:45 AM
lj8215
Jan 14, 2017 09:48 AM
dgiroux
2004 - 2008 F150
Jul 30, 2012 01:55 PM
patrick.sellers
2004 - 2008 F150
Oct 30, 2011 11:50 AM
