Sponsored by: Auxito
How much antifreeze?
Old Apr 5, 2019 | 07:08 AM
Michael Ward's Avatar
Michael Ward
'99 F150 4.6L. Had some leaking issues that I've been fighting and just got things buttoned up last night with no apparent leaks finally. Truck is surely mostly water for coolant at this point - but since it looks like I got the leaks taken care of I want to get it back to a reasonable coolant mix. I figure I'll drain the radiator, but how much water would be left elsewhere that I need to account for? Would a simple 50/50 mix refill be close enough?
Old Apr 5, 2019 | 07:34 AM
steve(ill)'s Avatar
steve(ill)
The system holds about 4 gallons and you will drain out about 2 gallons... After a good flush and drain, I normally add 2 gallons of 100% and then warm up / circulate and see what the mixture measures.... If you get -30 degrees or so, that's fine... If it measures 0 or 5 degrees, drain out a gallon and then add another gallon of 100%. .............. 50-50 will not get you there.
Old Apr 5, 2019 | 07:37 AM
steve(ill)'s Avatar
steve(ill)
I don't know what you used to flush, but if its "city water" it might be OK... If you used "well water", then you might want to buy 5-6 gallons of Demineralized water and do a couple flushes before adding the antifreeze... You would like the water that is LEFT IN THE MOTOR after the flush to be a DM type water without calcium / iron / etc. deposits.
Old Apr 5, 2019 | 07:43 AM
Michael Ward
I use distilled water for my 50/50 mixes. Didn't realize that much was left in the system after a radiator drain. City water in there now,
Old Apr 5, 2019 | 11:19 AM
Bluegrass 7's Avatar
Bluegrass 7
Best way to really know is use a Hydrometer for freeze point determination.
Drain system, add coolant mix or straight antifreeze while the engine is running so it mixes with what water is left.
Keep adding and checking at the fill reservoir until your satisfied with protection level then complete to fill line.
This fill procedure helps insure the air purges out of the system.
After the engine "cools completely", slowly turn reservoir cap and note if you hear a noise indication a vacuum is being passed.
If yes, the system is sealing, if no you still have a leak at some location or may even be the Cap..
An air leak does not allow full pressure to develop in the system and lowers the max operating temperature.
Be awhere there often can be a cold leak that seals when the engine comes up to temperature.
This shows as having to add coolant with no obvious leak when it's a cold leak above the coolant level.
Good luck.
Old Apr 5, 2019 | 04:16 PM
pdqford's Avatar
pdqford
Why don’t you pull one of the block drains? (That’s where all the crud build up hides).
AndeyHall
Nov 21, 2009 07:14 PM
Brownbear13
1997 - 2003 F150
Apr 2, 2008 09:54 PM
billy3p
25
Sep 26, 2007 11:39 AM
the winemaker
Jan 15, 2007 08:47 PM
ExcellentRed
Aug 12, 2004 02:09 PM
