Sporadic No start
Old Apr 2, 2019 | 06:51 AM
riverrat41's Avatar
riverrat41
Sporadic No start
02 F350 with 368k
In February I was getting some no starts after driving 30 minutes,killing the motor for an hour and then go out and NO Start.After about three times I changed out the CPS to a Motorcraft black one.Up until yesterday morning I have had 0 no starts and all has been fine.Yesterday morning I drive 30 minutes,kill the truck,go back out in about an hour No start.After cycling several times and trying to start it 3 times it fires up just like normal on about the 4th time.I drive on to work.Fires right up after work and the next several times on my way home after stopping and starting up again.
This morning it fires up fine on first start.Drive 30 minutes,kill the truck,come back out in an hour,NO start.....Try starting it 4 times,No start.I get out and unplug the CPS and check the wires,I do not see nothing out of the ordinary??Plug it back in,get back in the truck and it fires right up.....This is after about 15 minutes of frustration.
Oil level/age is fine.All gauges come on just as always.Batteries good...All sounds are the same for pre start.
Many Thanks for your help!
Old Apr 2, 2019 | 12:36 PM
HP junkie's Avatar
HP junkie
Look at the ignition. My dad was having similar issues with his Ex. He replaced the ignition cylinder and so far no issues. Could be same or could be worse.......electrical gremlin!
Old Apr 8, 2019 | 12:04 PM
riverrat41's Avatar
riverrat41
That could be the case beings it has not happened again so far??We will see.
Old Apr 8, 2019 | 04:09 PM
Wes444's Avatar
Wes444
At 1st i was wondering if it's the tin nut on IPR.
Later in the story if shutting the door affected the no start.
Old Apr 17, 2019 | 02:14 PM
riverrat41's Avatar
riverrat41
Layed me smoooooth down this morning after starting and running fine 2 times within an hour.The third time I go out to start it it and will not start for sh>>>>>>T.
I put another new CPS on it just to see but that did not work.Started looking at the ICP and IPR numbers on my Aeroforce gauge.
When cranking the ICP would not get over 249....The ICP DC% was 64.7.
I am not the smartest here on these numbers by no means so I am relying on ya'll??
Installing a new ICP sensor I had DID NOT make it start.
Old Apr 17, 2019 | 02:16 PM
riverrat41's Avatar
riverrat41
Sorry....towed it home and got into my 2012 to head back to work so I have not checked the IPR yet.I do know about IPR issues we have seen.
Old Apr 17, 2019 | 02:52 PM
pilgrimbizket's Avatar
pilgrimbizket
+1 on checking the IPR. The wiring maybe going bad on it as well. I would ohm out the IPR pigtail especially if the the tin nut is on the back and is nice and snug.
Old Apr 17, 2019 | 03:49 PM
riverrat41's Avatar
riverrat41
Many Thanks.I plan to check it this evening.
Old Apr 17, 2019 | 03:51 PM
Walleye Hunter's Avatar
Walleye Hunter
How's your oil level?
Old Apr 18, 2019 | 06:36 AM
riverrat41's Avatar
riverrat41
Tin nut is in tacked and tight.Oil level and life is good.Wiring showed to be good by the eye but did not get a chance to ohm it yet.
What should the ohms be and is that with the key on?
I will get another IPR headed my way JIC.Probably time.
kx125str99
24
Dec 19, 2017 06:35 PM
srauner
15
Aug 27, 2012 10:58 AM
IM1096
22
Dec 10, 2008 07:44 PM
IMRAY69
Mar 19, 2006 08:11 AM
SprintRacer26
Apr 8, 2005 02:43 AM
