I have an FE engine with 66 427 on the block (bellhousing side) with no casting numbers. Just curious because cylinders measure about 4.070 inches and I believe that is what a 390 is.
Reason: Adding information
Some drunk at the factory failed to swap out the mold pieces.
Look on the web for tips on identifying the possibility of this being a 428 capable block.
There is a 428 block for sale on the FeForum that has the 66-427 casting numbers.
