AFAIK based on post after post after post on this site, no casting or other number on an FE block will tell you anything about displacement.
All blocks had either '352' or reversed '105' on them, and could be 352/360/390/428.
The date codes & casting number--look down by the starter IIRC--might eliminate 352 if '68 or later, or eliminate 360 if before '68, but thats not watertight either.
Is this supposed to be the OEM engine in a 4x4? 360 if so.
