Experiencing loss in power and flashing OD light. Not many certified ford dealers in my area to help.
Getting the following codes, not read by a pro ford scanner. 4x4 switch has been removed.
What could it be? Where do you recommend to begin looking?
Flashing OD means you have tranny issues with overdrive slipping. I had this happen on my 95 TD. I found a used one for 250 bucks with 80k miles, installed it and sold it. I didn't want to grind up another auto with Diesel torque so i bought an 02 with a 6 speed handshaker.
No, it doesn't. A flashing OD light means transmission codes are stored. A slipping overdrive is one of about 50 different reasons that the light could flash.
Hi,
Pretty much all transmission related. It looks like I have a HD rebuild for me in the the near future...
Your problem is in the wiring or grounds, not the transmission itself. Installing a new transmission won't fix this, you will still have the same problem.
We´ve gone through the tranny wiring, grounds and fuses. No culprits found yet... Any other guesses?
Could it be a failure in the solenoid?
The tranny is sealed with silicon (!?) from PO so obviously been intervened. We will have to open and check, while doing so will go ahead with a quality rebuild kit.
