Overdrive light flashin
Old Mar 30, 2010 | 06:11 AM
bjis's Avatar
bjis
Unhappy Overdrive light flashin
Ok well 2000 EX and my overdrive light starts to flash and the truck dies out. Last week it did the same thing and the engine light came on a code po720 output shaft speed sensor i replaced it but the overdrive light still flashes about once a day but no codes now. Should i start cryin now lol
Old Mar 30, 2010 | 10:59 AM
Stewart_H's Avatar
Stewart_H
What did you use to read the codes the first time? What engine do you have in your rig?
Stewart
Old Mar 30, 2010 | 12:11 PM
rlh68050's Avatar
rlh68050
You need a scan tool that will read codes from the Transmission module. If that light is flashing there are codes set. Snap On, OTC, or the Ford IDS will do it.
Old Mar 30, 2010 | 02:50 PM
bjis's Avatar
bjis
Innova scaner and i have the 6.8 V-10 so i got to take it to the shop or buy a scanner for the tran ? Thanks for your input
Old Apr 1, 2010 | 10:16 PM
bigbugman's Avatar
bigbugman
mine has been doing the same thing i wound up running a ground wire from battery ground to the p.s. head and have not had a problem since, worth a try.
Old Apr 2, 2010 | 08:13 AM
rlh68050's Avatar
rlh68050
The Innova scan tool will only read generic OBD codes of which none are transmission. You need to find someone with one of the high end or OE scan tools. A real mechanic will have one.
Old Apr 2, 2010 | 10:44 AM
TYZ78F150's Avatar
TYZ78F150
I have one from sears and it was $180, and it reads anything. Any code starting with "P" means powertrain,engine,tranny rear,etc...
Old Apr 5, 2010 | 02:50 PM
bjis's Avatar
bjis
OK thanks guys i will let you know whats up.. i was off on a camping trip for Easter
Old Apr 5, 2010 | 10:09 PM
GeoQwest's Avatar
GeoQwest
Flashin O/D light
I had this problem a few years ago. There were a bunch of suggestions somewhere in this forum....somewhere. There was a lot of big scarey talk like "limp mode of a dying transmission" and torque converter problems.
My stalling and flashing went away when I changed the alternator voltage regulator. I did it for an unrelated issue and the stalling and flashing were gone. Cheap and quick swap out.
Beats me why, but it worked.
Good luck.
Ziob
Nov 29, 2019 07:37 PM
ibew481
1983 - 2012 Ranger & B-Series
Jul 13, 2016 10:19 PM
brad3504x4
May 9, 2015 06:36 AM
azpowerstroke
May 7, 2012 10:30 AM
jbs08
Oct 24, 2011 09:39 PM
