Keyless remote control receiver
Old Mar 29, 2019 | 11:10 PM
Iraa's Avatar
Iraa
I'm trying to locate the receiver for the keyless remote door unlocker/locker. It's a 1994 Ford, F-150, std 2-door cab, 5.0l engine. I need to know whether this truck came originally with remotes and receiver dealer installed. The vin is 1FTEF15N5RNA77560. Maybe, with the vin someone can determine if the truck came originally with the remote keyless entry system. Thanks, Iraa
Old Mar 30, 2019 | 07:39 AM
tjc transport's Avatar
tjc transport
i ain't rite
this is an old thread, but it should help you :
https://www.ford-trucks.com/forums/9...ess-entry.html
Old Mar 30, 2019 | 07:55 AM
seville009's Avatar
seville009
You wouldn’t be able to tell by the VIN if it had that option unless you have the dealer look it up; it doesn’t show anything here https://vincheck.me/ford/f-150/1ftef15n5rna66297/
if you have manual locks, then clearly you don’t have the system
this vendor sells the transmitters. Send them your vin and they can check. Maybe if you contact them they could tell you what to look for to see if you have a receiver already in your truck
https://myaccount.carandtruckremotes...rchmodel=F-150
Old Mar 30, 2019 | 09:39 AM
goodB0Y's Avatar
goodB0Y
*Deleted post*
Old Mar 30, 2019 | 02:25 PM
Iraa's Avatar
Iraa
I have a remote that came with the truck, but it's the wrong remote. It still worked for a while sometimes intermittently. Now, it will lock the doors but not unlock them. I have ordered the correct remote and will need to reprogram the new remote when it arrives. Does anyone know where the problem might be when it still locks but will not open the doors. Could this problem be on drivers side on floor under the plastic "door sill"?
Old Mar 30, 2019 | 03:29 PM
seville009's Avatar
seville009
have you tried putting a new battery in the remote? When the battery starts dying, it doesn’t completely die, it just starts acting quirky.
Old Mar 31, 2019 | 03:43 PM
Iraa's Avatar
Iraa
Took your advice and installed new battery. No change.
tim051
Aug 7, 2013 05:38 PM
cookieduster
Dec 23, 2011 09:34 PM
jp1096
Jan 6, 2011 10:26 PM
Buffalo250
Apr 27, 2010 01:58 PM
Prometheus
Jan 30, 2006 05:03 AM
