Keyless entry
Old Dec 17, 2011 | 08:39 AM
cookieduster's Avatar
cookieduster
Keyless entry
How can I find out if I have factory remote keyless entry system installed on my 2003 explorer.
Many Thanks
Old Dec 17, 2011 | 11:53 AM
turborich's Avatar
turborich
I'm pretty sure they all had the factory remote for locking/unlocking the doors. You can buy a new key fob for around $20.00 or less if you look around. You can also program it yourself. Instructions should be on this forum or just google it.
Good luck
Old Dec 18, 2011 | 04:15 PM
1081's Avatar
1081
I am pretty sure you you can call the dealer parts dept. and give them the VIN and they can tell. Or... see if it goes in to program mode like you were programming a remote. It used to be where you would turn the key on/off five times, stopping in the on position, then the locks would lock and unlock to confirm you're in program mode.
Old Dec 19, 2011 | 12:12 PM
ncranchero's Avatar
ncranchero
Plug your VIN into THIS site and it'll give you the options your vehicle was produced with.
Old Dec 22, 2011 | 10:57 AM
cookieduster
I tried this but now I cannot get it out of the programming mode. Whats up here.
Old Dec 22, 2011 | 11:59 AM
ncranchero's Avatar
ncranchero
You tried the what, the 5 on-offs? When you turn it to off and remove the key it will be out.
Old Dec 22, 2011 | 08:48 PM
cookieduster
Thanks Bud ............! Is there any info on how to program the belt minder or seat belt reminder other than the owners manual. I have to admit today I was a little worried after doing the key on and off five times, I did get it into some kind of mode that continued to operate the buzzer. The only way I could stop it was to disconnect the battery minus. Eventually it started working again but now I have the door lock unlocked somehow. I have to use the key now to lock the only door that has a key lock and that is the drivers door.
Old Dec 22, 2011 | 10:29 PM
1081's Avatar
1081
The car should automatically exit programming mode after 30 seconds. I am not sure about the buzzing. What did you unlock it with before? You said you have to use the key now.
Old Dec 22, 2011 | 10:36 PM
1081's Avatar
1081
How to Program the Ford Explorer Remote Door Lock | eHow.com
programming remote
Old Dec 23, 2011 | 08:29 AM
cookieduster
All this started because I wanted to know if I had the key fob system installed. I still don't know.
I tried the example, turn your key on and off five times ending with on.
(I have only the key lock on the drivers door, that works O.K.)
So after the episode of turning the key on and off five times, I'm pretty sure I set the computer to change the Autolock feature somehow.
Now, when I push the button to Lock the doors, the computer immediately unlocks the doors. So I have to use the key to lock the explorer now.
So somehow I changed that autolock feature somehow.
I still have not determined if I have the system installed that will allow me to buy a key fob and program it to lock and unlock the door locks.
Old Dec 23, 2011 | 09:34 PM
1081's Avatar
1081
I would say that if you have the autolock system you can program a key fob to lock and unlock it. Just do a Google or Yahoo search for programming the autolock system for your year and model and you can re-set the autolock feature.
jp1096
Jan 6, 2011 10:26 PM
swervin22
Jan 8, 2008 04:25 PM
MrSlithers
1997 - 2003 F150
Apr 24, 2007 10:25 AM
Biscayne
Aug 10, 2005 07:12 PM
Code 5 Ford
Nov 10, 2003 03:37 PM
