Speedometer 6MPH high
Old Mar 28, 2019 | 08:22 PM
markcarp's Avatar
markcarp
8th Gear
Just got a 2012 F-150 XL 4x4 w/101K miles. It was a fleet truck in North Dakota. Speedometer is reading about 6 MPH high everywhere from 25MPH up to 70MPH (and beyond I assume). Took to dealer and they reset computer to current tires (265/70R17), but that made no difference (not surprising) since the calculation shows they are only 0.5% different (speedwise) from stock LT245/75R17 tires.
I did notice something on the Carfax - at 12K miles the axles were checked and differential ring gear & pinion replaced. I assume that wouldn't have an impact, but it seemed weird. Is there anything else axle/differential related that I should look for?
I've seen the threads on calibrating the speedometer myself, but not I'm comfortable with that. I'm taking it back to the dealer - is there anything specific they should do?
Thanks,
Mark
Old Mar 29, 2019 | 08:55 PM
steve(ill)'s Avatar
steve(ill)
Speedo can not be off 6 MPH at 25 and also at 75 MPH....... it is linear... If it was off 6 MPH at 75, it should be off 2 MPH at 25... Your talking about 10% off in speed.. That would be hard to do.. Where are you getting the 6 MPH ?
Old Mar 29, 2019 | 11:56 PM
markcarp's Avatar
markcarp
8th Gear
I understand what you are saying - I would have expected it to be linear also. But I checked it against my GPS (which is confirmed accurate in other vehicles) and against mile markers. Speedo was was probably reading 5 low at 20 MPH, then 6 low at 60 MPH, so there's a very slight change but definitely not linear. It seems like there just a constant offset of 6 MPH.
Old Mar 30, 2019 | 10:14 AM
alloro's Avatar
alloro
Then that's an issue with the speedometer gauge and not the vehicle speed sensor or programming.
Old Mar 30, 2019 | 09:08 PM
steve(ill)'s Avatar
steve(ill)
YEP......... you could pull the needle off the shaft and reinstall it a few degrees off.......... that would be CONSTANT.
Old Mar 31, 2019 | 02:06 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Do you have the information screen in the dash? If so, scroll to the digital speedometer.
If you don't, try using Forscan to pull the speed the computer is outputting.
Old Mar 31, 2019 | 02:26 PM
markcarp's Avatar
markcarp
8th Gear
Unfortunately I have an XL with just the analog gauge and minimal digital information.
But based on previous comments I just checked the speedometer when stationary and it shows well below zero. By the time it gets up to zero the GPS shows 8MPH, so it does appear to just be a constant offset.
I plan to just pull off the instrument gauge cover and zero out the needle. Will that have any unintended consequences, or anything I should be careful about? Thanks!
Old Mar 31, 2019 | 05:27 PM
steve(ill)'s Avatar
steve(ill)
you might look up on You Tube or something like that... Setting it at ZERO might be one idea... I did an explorer several years ago and it seems like you connect a 1.5 volt battery to a couple terminals, then put the needle on at 60 MPH or something like that...
Old Mar 31, 2019 | 05:32 PM
ford390gashog's Avatar
ford390gashog
Was the truck off or running? The stepper motor will only bring it to zero with the truck running.
Old Mar 31, 2019 | 10:04 PM
markcarp's Avatar
markcarp
8th Gear
The truck was running when I read the speedometer. However, I turned it off and then back on and the speedometer needle never moved, so it appears to be pegged at the minimum stop.
Old Apr 1, 2019 | 01:41 PM
steve(ill)'s Avatar
steve(ill)
Old Apr 1, 2019 | 02:24 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
I agree that changing a gear ratio during the Carfax event would have given a wider difference as speed accumulated. I also agree tire-size difference between stock and current is only 0.3% by my math, which would yield a 1MPH difference at just under 334MPH.
The +6MPH thing makes sense to me as a spindle-clocking problem with the speedometer stepper motor until I read posts 3 and 7. Then I get:
indicated=actual (source) offset=(actual minus indicated)
-1=00 (from post 7) offset=-1
00=08 (from post 7) offset=08
15=20 (from post 3) offset=05
19=25 (from post 1) offset=06
24=30 (from post 1) offset=06
29=35 (from post 1) offset=06
34=40 (from post 1) offset=06
39=45 (from post 1) offset=06
44=50 (from post 1) offset=06
49=55 (from post 1) offset=06
54=60 (from post 1) offset=06
59=65 (from post 1) offset=06
64=70 (from post 1) offset=06
So it appears to be non-constant after all? If true, this would strike me as more than a spindle clocking issue with the needle on the stepper.
If it were me, I'd use TorqueOBD2 or similar to observe the speed that the computer thinks it is doing versus the indicated speed on the speedometer. If that showed the same as has been posted in this thread, I'd grab a cluster from a junkyard and see what it does across the same range.
Old Apr 2, 2019 | 12:00 AM
markcarp's Avatar
markcarp
8th Gear
Thanks to all for the helpful advice. I've got a Forscan adapter coming Wednesday (and now a Bluetooth adapter as well), so I'll see what speed the computer is showing. I did a rough check with my automatic locks today - they locked as expected at 12MPH on the GPS.
Old Jun 7, 2020 | 04:51 PM
markcarp's Avatar
markcarp
8th Gear
Originally Posted by steve(ill)
Sorry I never replied until now, but this video was exactly what I needed. I followed this procedure and the speedometer has been right on ever since. I just had to repeat it last week when the needle broke off during the night (strange) and it worked again. Thanks so much!
Old Jun 7, 2020 | 07:48 PM
meborder's Avatar
meborder
deleted my own post.
metru
Nov 8, 2017 09:26 PM
ibewshooter
2015 - 2020 F150
Sep 27, 2017 05:32 AM
glenhunt
May 30, 2015 08:07 AM
SPL Tech
Apr 2, 2007 05:11 AM
karenj
Jun 16, 2004 08:38 AM
