Vibration help needed
Old Mar 28, 2019 | 08:03 PM
Dohara's Avatar
Dohara
1951 f1, just replace rear motor mount and have bad vibration just before I shift into 2nd and 3rd. Also at 40 mph and above. Any help?
Old Mar 29, 2019 | 08:43 AM
moejr's Avatar
moejr
Do you mean the transmission mount? Check to see it's seated properly and the drive shaft / U joints are in good shape.
Old Mar 29, 2019 | 10:57 AM
Dohara's Avatar
Dohara
ok will double ck the trans mount - after the vibration I had 2 new u-joints installed and had the drive shaft balanced
Old Mar 29, 2019 | 11:11 AM
moejr's Avatar
moejr
So are you saying that the vibration started after the new driveshaft was worked on? I would have the shop recheck their work, you should also check the driveshaft phasing.
Old Mar 29, 2019 | 02:52 PM
Dohara's Avatar
Dohara
No it started after new trans mount install- we thought maybe in drive shaft so sent it to get balance and have both u joints replaced
Old Mar 29, 2019 | 03:23 PM
moejr's Avatar
moejr
New trans mount same size as the old one? Pinion angle within specs?
Old Mar 29, 2019 | 05:39 PM
Dohara's Avatar
Dohara
mount was same bought it from Dennis Carpenter- as soon as I drove after new mount that’s when vibration started. Took to work my guy thought maybe u joints and or needed to drive shaft re balanced-which I did - then went to install the shaft and the yoke was too short - so had them install a longer yoke . Vibration happens just before I go into 2nd and 3rd and then starts around 40 mph . My cell is 336-408-6800
Old Mar 29, 2019 | 07:46 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I have a 52, and replaced the mushy stock mount with a DC mount (made in India). It is as hard as rock. Ever since I have felt a lot more vibration than I think is appropriate. Don't know what we can do, not sure I'd trust an OEM that's been on the shelf for 30 years.
Old Mar 29, 2019 | 08:08 PM
Dohara's Avatar
Dohara
my vibration is really bad can’t drive on highway
Old Mar 30, 2019 | 07:06 AM
Greg Rogers's Avatar
Greg Rogers
Not a expert but from what you say it sounds like a engine RPM thing?? If you say it does it at the top of 1st and 2nd gears then in 3rd gear at higher RPM? If you have a tach or can tell by sound that the vibration occurs at a certain engine speed then I would look at engine/flywheel/ clutch/input shaft in trans,etc. If you engine isn't firing evenly on all 8 it can cause quite a vibration with a stick shift. Can you get the vibration to come on if you slowly rev up the engine in neutral? Good luck!
Old Mar 30, 2019 | 07:14 AM
bigwin56f100's Avatar
bigwin56f100
Obviously, if the mount is correct and correctly installed you would not have need to lengthen the yoke.
Sounds like the drive line angle is wrong at the rear of the trans.
you answered your own question, it had no vibration before you changed the mount, so the mount or the install is wrong
Old Mar 30, 2019 | 08:09 AM
Dohara's Avatar
Dohara
yes I will also vibrate in neutral when pressing the gas . All this started after replacing the trans mount
Old Mar 30, 2019 | 10:16 AM
Rust Wrangler's Avatar
Rust Wrangler
If this is the case, then the driveline assembly is not causing it. The vibration may be caused by something between the back of the engine and the front of the transmission.
You should check the clutch assembly and flywheel. Possibly something is coming loose there. The engine firing order should also be verified, as it can run out of order, but will vibrate badly.
http://www.vanpeltsales.com/FH_web/F...ng_49-53v8.jpg
Old Mar 30, 2019 | 10:21 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Originally Posted by Rust Wrangler
If this is the case, then the driveline assembly is not causing it. ...The engine firing order should also be verified, as it can run out of order, but will vibrate badly.
Spot on! I would add, the radiator fan and front motor mounts are suspect. Unless the clutch was touched during the rear mount work, doesn't seem that would be the problem.
Stanlystutz
16
Dec 29, 2024 09:04 PM
oscoda455
34
Jul 10, 2016 08:12 PM
brian Felts
Sep 28, 2010 05:07 PM
MSC
Feb 10, 2006 08:20 PM
mmx2000
Dec 29, 2003 07:44 PM
