4R70W Torque Converter Drain Plug
Old Mar 28, 2019 | 01:03 PM
2000E150's Avatar
2000E150
Hello,
Does anyone know if all 4R70 torque converters have drain plugs ? I have a 2000 E150 5.4 and have tried several times to use the starter to rotate the converter and locate the drain plug. I have made sure the rotation increments are small, but still have never had the plug appear within the plug access opening.
Thanks for your help.
Jason.
Old Mar 28, 2019 | 06:20 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
A 2000 4R70W left the factory with a drain plug in the torque converter.
Get a socket to fit the hex inside the pulley on the front of the crankshaft. You can turn the engine by hand while watching the torque converter.
Old Mar 28, 2019 | 08:31 PM
2000E150's Avatar
2000E150
Thanks for the reply Mark. I did try that approach but had no success moving the crank. I'm only on ramps - no lift, so leverage is limited. I may try to remove the serp belt to lose some of the drag and try that again. Should I have any concerns that I would torque the crank pully nut tighter than the torque spec it was put on with, if the compression does not let me move the crank ?
Thanks.
Jason
Old Mar 29, 2019 | 04:31 AM
JWA's Avatar
JWA
If you're draining the TC to do a full fluid exchange aka "flush" as Mark so well details in his excellent article found here on FTE: Mark's Full Flush Article It works perfectly BTW!
Old Mar 29, 2019 | 01:27 PM
Mark Kovalsky
Thanks.
Jason
You need a longer wrench. I've turned a 7.3L diesel with this method and it has a lot more compression than any engine connected to a 4R70W. Don't worry about over torquing. That isn't going to happen.
Old Mar 31, 2019 | 09:31 PM
2000E150's Avatar
2000E150
JWA thanks for responding and providing that great link. That would have been much easier, will definitely utilize for the next change.
Mark thanks for the reply and sharing your expertise - extremely helpful, generous, and much appreciated.
One last question - when the plug is tightened should the head go all the way to the TC ? I thought when I extracted it the head was flush against the TC, but will not go that far now before it's tight and I hit the 7 ft lbs. I did see some pics on the web showing a gap between the two. I know some of these plugs are self tapping and threads are not the same once removed.
What a great site !
Thanks again.
Jason
al0311
Aug 22, 2015 08:58 PM
05ExcursionLTD
Jun 19, 2009 07:15 AM
ispurlock2000
Aug 6, 2007 06:01 PM
mike L
Apr 10, 2006 06:04 PM
KennyG228
Feb 16, 2004 11:06 PM
