Steering box bad?
Old Mar 28, 2019 | 06:55 AM
milkstake's Avatar
milkstake
Steering box bad?
Morning.
I have a daily driver project 97 cclb with 6" lift and 35 inch tires. I plan on restoring the truck to like new, but i am moving states before that happens. Hopefully next few weeks. I need to drive the truck about 900 miles to our new home. A few weeks ago i was dinkering with my steering shaft because of the play it seemed to have while driving, i noticed the shaft(s) were loose where they meet. I got a bright(dumb) idea to put a hose clamp around the 2 shafts to tighten them up. It worked!!! Steering felt great...... now i think i pissed off the steering box, because it is loose entering the gear box.
New replaced right?
Im literally in the process of moving out of my house and probably need to have someone do the repair since my garage is packed away. Anyone have insite or advice on what i should expect to pay or any other problems there may be?
Thanks in advance
Old Mar 28, 2019 | 08:32 AM
knottyrope's Avatar
knottyrope
Steering box has an adjustment on it, it cant be too tight or it will stick/bind but you might be able to take some slop out of it.
If that don't work then time for a https://redheadsteeringgears.com/
Old Mar 28, 2019 | 10:03 AM
milkstake's Avatar
milkstake
Is it obvious when it is too tight? Or will it just keep tightening
Old Mar 30, 2019 | 02:00 PM
fordpride's Avatar
fordpride
If you don’t know how to adjust the gearbox then leave it alone
Old Mar 31, 2019 | 07:11 AM
milkstake's Avatar
milkstake
Well i guess ill never learn then. Have to be born an expert i guess.
Old Mar 31, 2019 | 11:23 AM
fordpride's Avatar
fordpride
Learning is one thing, learning on one that is in use on the road is another. If it’s too tight the steering can get locked up causing you to not be able to steer.
If you want to try it then loosen the lock nut and turn the adjustment screw in 1/8” turn at a time then go drive it. Repeat till you get it where you want it. When it starts to get to tight the wheels will start not to return to center.
Old Mar 31, 2019 | 11:28 AM
fordpride's Avatar
fordpride
ExplorerTominCO
Aug 16, 2016 04:30 PM
1992FordF150Custom
Sep 8, 2012 06:53 AM
jsalty
Nov 17, 2009 06:40 PM
agryphon
1983 - 2012 Ranger & B-Series
Sep 28, 2006 10:11 PM
BluesManF250
Jan 11, 2004 11:27 PM
