1952 Steering Column
Old Mar 25, 2019 | 12:51 PM
JAuch01's Avatar
JAuch01
Hey, I'm looking for a steering column for a 1952 M3. The one that is in my truck has damaged threads and would like to replace, please let me know if anyone out there may have one to sell.
Jim
Old Mar 25, 2019 | 05:58 PM
BlueOvalRage's Avatar
BlueOvalRage
Are you referring to the threads for the steering wheel retaining nut? If so, then you don’t need a steering column. You need a new steering gearbox. That shaft is one piece down through the column and into the gearbox. The worm gear is pressed onto the end of it. The steering column will slide off of it once the clamp at the gearbox is loosened.
If you’re handy, then the shaft and worm gear are sold new as a unit. It would be possible to rebuild your box and replace them.
If you’d rather find a used unit, any box from a 1948-52 F/M1,2, or 3 will fit.
Old Mar 25, 2019 | 06:13 PM
JAuch01's Avatar
JAuch01
Thanks for the info. I am pretty handy in the garage. Must seek out a new steering shaft and gear.
Jim
Old Mar 27, 2019 | 05:21 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
7HC-3524 .. Steering Shaft & Worm Assy - 43 23/32" long / Worm stamped: 97 / Obsolete
1948/52 F1/F2/F3.
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
JNye
Jan 24, 2019 04:03 AM
hawk1959
13
Oct 15, 2014 12:05 PM
safari1957
Jan 13, 2012 12:43 PM
onepeiceatatime
Apr 4, 2007 09:20 PM
19Seventy7HiB0y4x4
16
Mar 20, 2002 09:12 PM
