Collapsible steering column
Old Jan 20, 2019 | 09:48 PM
JNye's Avatar
JNye
Hello people, this is my first post here. I have a 54 F-100 that’s going through the typical frame off restoration. Trying to keep things relatively stock except for a few safety upgrades.
I was working on the steering box today and got to looking at the solid steering shaft. I suppose in an accident that shaft could go right through your chest and game over.
Is that a reason people add after market steering columns like ididit? Are those collapsible in an accident? Do they use a different steering shaft? Your experiences and advice will be helpful. Thank you, John
Old Jan 21, 2019 | 07:28 AM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
First off: Welcome to FTE JNye
To the best of my knowledge (someone will jump in if I’m wrong) none of the aftermarket columns are collapsible. You’d need a junkyard column to get that.
Most of the folks that are changing their columns are doing so because they are changing their steering gear/suspension to such things as at Toyota power steering box, series 400 box from CPP, a Mustang II, Volarie, Jag, Crown Vic or the many other front suspensions installed in our F1s & F100s.
Yes, the steering shaft (steering gear & pitman arm too) is removed and the new column takes it’s place. The new column is installed using rag joints or U joints between the steering gear (or rack and pinion) and the column.
Old Jan 21, 2019 | 08:19 AM
ben73058's Avatar
ben73058
Hey JNye,
Welcome Aboard! Show us some pics of your truck when
you get a chance & tell us a little about it. We replaced our steering
column with an Ididit as the stock steering on these old trucks can be down right scary
in it's normally worn out condition. Our truck would move all over the road without moving the wheel.
The Toyota steering box fits in virtually the same place as stock & is a nice modern unit.
Good to see another truck being saved up there in Utah!
Ben in Austin
1950 F1
Old Jan 21, 2019 | 10:37 AM
52 Merc's Avatar
52 Merc
Welcome to the forum! Your concerns for safety are well founded. The solid steering shaft can act like a spear through the chest in the wrong circumstances. However, with the steering box far behind the axle centerline, it's not in the direct line of impact of a frontal collision and is less likely to hurt you that way than having your body impact the steering wheel directly in a crash without proper 3 point restraint.
What BJ said is correct, in that changing the column is more a result of changing something else, rather than adding it to the stock steering box. Aftermarket columns are available in a collapsible style from Ididit, but most of them are not. The collapsability can be added into the design with a collapsable shaft between the column and the steering gear, which is how the OEM typically does it. Another way to attain a level of safety is to have U-joints and angles in the shaft that would give in the event of a compression, rather than push toward you.
https://www.ididitinc.com/i-25048740...tegory:1310139
Slip Shaft Kit (No Universal Joints) - FR1856 - 577 - 5874
Old Jan 21, 2019 | 04:50 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
FoMoCo collapsible steering columns: 1968 and later passenger cars, 1980 and later F100/350, Bronco & Econoline.
Ranger/Bronco II/Aerostar/Explorer and etc vehicles that were introduced after 1980.
Old Jan 21, 2019 | 07:49 PM
hooler1's Avatar
hooler1
In 56 they changed to a dished steering wheel . I remember reading somewhere that in 56 that helped turn the steering column into sort of an energy absorbing device.The idea being that during a collision causing a body to be thrown forward, the chest would hit the outside of the steering wheel distributing the force over a larger area as opposed to getting thrown into the horn button. If that is all true I do not think I would want to be the crash test dummy. I am just happy being a normal dummy.😉
Old Jan 21, 2019 | 08:04 PM
abe's Avatar
abe
The deep dish steering wheel was part of the Life Saving features in the 1956 Ford trucks which included a different striker plate with a cover on it to keep the door latched in an accident, and optional seat belts.
And that is why the 56 column is a few inches shorter than the 53-55 column.
Old Jan 21, 2019 | 08:26 PM
CharlieLed's Avatar
CharlieLed
This is like arranging deck chairs on the Titanic...if you are concerned about vehicular safety then don't start with a vintage truck. There have been other discussions on this topic in the past years and many aspects of these trucks that are not "up to code" were discussed. Seating, hard dash, safety restraints, headrests, fuel tank inside the passenger compartment, back window too close to occupants heads, the list goes on and on. I don't want to minimize the need for safety but in the mid-fifties when these trucks were built safety was keeping the rubber on the road and between the lines.
Old Jan 22, 2019 | 12:44 PM
NumberDummy
All 1956 Fords had a "deep dish" steering wheel. The cars had a chrome steel horn button or horn ring with a plastic center emblem.
Can you imagine what would happen if your noggin struck that horn ring? You may end up looking like Rondo Hatton, the most gruesome of all Hollywood actors.
1956 Ford passenger cars had an optional safety package that included a padded dash and sun visors, lap seat belts (the metal to webbing "airplane" type).
The package didn't sell worth a hoot and so it went bye-bye after 1956.
Old Jan 22, 2019 | 03:27 PM
52 Merc's Avatar
52 Merc
Here's a Ford safety video made in 1956 discussing all of the items brought up here, safety steering wheel, seat belts, door latch and strikers, wrecks and crash dummies, etc. It's worth a look.
Some of us old guys may recognize the video host, a young Art Fleming, who later was the original host of 'Jeopardy!' back in the 60's.
Old Jan 22, 2019 | 03:57 PM
NumberDummy
https://www.youtube.com/watch?v=R3ZnrHGRvE8
Are you sure this is the same Art Fleming from Jeopardy? This guy doesn't look very young to me with his balding pate and baggy eyes.
He also looks heavier than the Jeopardy Fleming.
Old Jan 22, 2019 | 07:56 PM
52 Merc's Avatar
52 Merc
The guy in the picture above is not Art Fleming. He's a Ford engineer showing off how safe their products are. Art is interviewing him. Watch the video and you'll see.
Old Jan 22, 2019 | 09:43 PM
JNye's Avatar
JNye
Thank you for all the good responses. A lot of interesting points. I agree it won’t be like a current car, safety wise. The steering column worry is probably overblown, I was more thinking of Ralph Nader and the Corsair. As one response pointed out the location of the steering box farther back plus the engine being there should help. I suppose as it will be mostly stock, it won’t be running 80 mph either. I was and still am planning to install as good quality seat belts as possible. As the video mentioned, staying in the vehicle during the crash is most important.
We milk cows for a living and have quite a bit of modern machinery with cabs and roll over protection. The manufacturers are all pretty emphatic about seat belt use.
Again thanks for your help. I am very much enjoying learning from you all.
Old Jan 24, 2019 | 01:03 AM
jimcar-9's Avatar
jimcar-9
Anyone happens to have a set of those door lock plates he was talking about? ready to part with :-)
Thanks in advance!
Ps. Really interesting video
Old Jan 24, 2019 | 04:03 AM
Justboy's Avatar
Justboy
I learned something too from this. I haven't bought a steering column yet but I did think the Ididit column was collapsible, I'm sure I saw a Youtube video where they showed the manufacture of it including the diamond shape cutouts on the shaft. But it must have been an even higher cost option I don't think I'll bother with!
JAuch01
Mar 27, 2019 05:21 PM
kevintoupin
16
Jun 22, 2017 04:30 PM
ranger332
Nov 14, 2016 04:34 PM
hawk1959
13
Oct 15, 2014 12:05 PM
tbird4
May 31, 2006 07:48 AM
