1996 Windstar ABS/Speedo problem
Old Oct 1, 2003 | 11:21 AM
mgdhunter's Avatar
mgdhunter
Question 1996 Windstar ABS/Speedo problem
I have a 1996 Windstar that the ABS light is on, and the speedometer is jumping around. Is it because of the ABS sensor, and if so, where is it located? I would like to try to clean it, or replace it if needed.
Thanks in advance.
Old Oct 1, 2003 | 11:59 AM
fishin1976's Avatar
fishin1976
You need to have the codes pulled for the ABS. I believe the windstar has multiple ABS sensors.
Old Oct 1, 2003 | 12:44 PM
mgdhunter's Avatar
mgdhunter
Is the Speedometer jumping in any way related to the ABS light coming on? Is it a separate problem?
Old Oct 1, 2003 | 01:01 PM
fishin1976's Avatar
fishin1976
It could be, but with OBD-II on that engine, you never know. I would assume that they are related problems. It could be the VSS sensor, which on those it would be on the transaxle some where. (VSS = Vehicle Speed Sensor). You really need the code to weed out the problem.
Buggie
Aerostar
Nov 23, 2013 11:07 PM
Pablo-UA
Aerostar
13
Oct 30, 2009 05:55 AM
windstarharv
Oct 15, 2007 07:30 PM
woods
Aerostar
Dec 24, 2005 11:22 PM
donaldora
General Automotive Discussion
Nov 28, 2004 07:27 PM
