"93"F-150 4x4 HARD STARTING
Old Sep 30, 2003 | 02:57 PM
gyger's Avatar
gyger
My Dad's F-150 is weird when you try to start it,
it's hard to start. If you give it gas it seems to automatically
flood it out. But if you just keep turning the key it
finally starts on it's own. But right after you get it
running if you tap the gas it will bog down and stall.
Forget trying to drive it if it's not been running for atleast
5-10 minutes. And it's not even cold here yet.
It has the 5.0 in it we replaced the distributor cap,
plugs, wires, fuel filter, air filter, and we ran some
gas additive through her.
Still the same response.
what do you guys think?
Thanks
Old Sep 30, 2003 | 03:05 PM
billman's Avatar
billman
You can always try to remove and clean the Idle Air Control Valve (IAC). Also, follow the Haynes manual in the testing of it.
Old Oct 1, 2003 | 08:31 AM
fishin1976's Avatar
fishin1976
Check your fuel pressure. Sounds like a weak pump. Give us a breif history on the truck, recent repairs made, milage, known problems, etc....
Old Oct 1, 2003 | 12:18 PM
gyger's Avatar
gyger
and it has like 155,000 on it right now.just started
doing this about three months ago. he doesn't drive
it much anymore.
anyway I'm going to run a fuel pressure guage
from the shrader valve on the fuel rail and attempt
to start the truck does anyone know what standard
psi is for this truck? I'm thinking about 40psi like most
efi fords
Old Oct 1, 2003 | 01:04 PM
fishin1976's Avatar
fishin1976
Fuel pressure Key on engine off should be 50-60, engine running should be 8-10 lower, fuel pressure running w/ FPR disconnected from vacuum should be 8-10 higher than the last test.
rlwilson2
13
Dec 13, 2012 04:05 PM
02f350gurl
30
Oct 27, 2010 06:45 PM
mattri
22
Mar 7, 2010 07:22 PM
adamham76
22
Mar 17, 2006 06:25 AM
STMTS
1997 - 2003 F150
Aug 1, 2004 08:51 PM
