Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Headlight Headache
Old Mar 24, 2019 | 08:52 AM
Gerald Bohmer's Avatar
Gerald Bohmer
Headlight Headache
06 XLT Escape. Was adjusting Passenger side headlight up, & had it almost where it needed to be, and the assembly dropped off the adjusting screw inside the housing. Is there a way to get at it to reattach it? or have I ruined a fairly new headlight assy???
Yep. I ruined a brand new headlight. There's no way inside the 'bubble' without destroying it.
Old Mar 30, 2019 | 05:39 PM
got2bjoester's Avatar
got2bjoester
I would think removing the headlight assembly and addressing it that way would be the answer.
Old Mar 30, 2019 | 06:27 PM
simonsi's Avatar
simonsi
To be honest you should remove the headlight assembly, something is not quite right if the adjuster needs winding so far and is still only “nearly there”.
If you are replacing the light due to impact damage then you may have some distortion to the metalwork that you havent noticed that will need correcting before the light will fit and adjust correctly...
Old Jul 11, 2019 | 02:41 AM
TexGuy's Avatar
TexGuy
Don't feel alone, We replaced both headlight assembly and 1 would not adjust. Got a replacement that would not adjust and the 3rd headlight assembly would adjust. So after pulling the bumper cover off for the 3rd time it was done.
ttoptom1
2009 - 2014 F150
Mar 6, 2017 10:11 AM
SailorKane
Jan 13, 2015 11:56 PM
O1COBRA
2004 - 2008 F150
Mar 3, 2008 03:33 PM
Rockstar
Paint & Bodywork
Mar 29, 2002 06:40 AM
