Headlight adjustment
Old Jan 24, 2008 | 07:42 PM
O1COBRA's Avatar
O1COBRA
Anyone know how to go about re-aiming the headlights to face up/down more?
Old Jan 25, 2008 | 05:46 AM
O1COBRA's Avatar
O1COBRA
nobody knows?!
Old Jan 25, 2008 | 06:01 AM
Joe04F150's Avatar
Joe04F150
Right behind the headlights is a very small (6 or 7mm?) adjustment stud...
Old Jan 25, 2008 | 06:14 AM
O1COBRA's Avatar
O1COBRA
Awesome. Thanks!!!
Old Feb 26, 2008 | 10:02 PM
dfishrmn88's Avatar
dfishrmn88
Does anybody know the measurements needed to adjust to after installing a 2" leveling kit?
Old Feb 27, 2008 | 01:51 AM
LACityFD's Avatar
LACityFD
Anybody know where you can get the headlamp adjustment tool? Pep Boys didn't have it over here...using a little wrench is a PITA.
Old Feb 29, 2008 | 10:31 AM
bansheeduner's Avatar
bansheeduner
i just used the wrench took two min
Old Feb 29, 2008 | 11:55 PM
FTE Trigger's Avatar
FTE Trigger
I'm starting to use a ratcheting wrench... (like a GearWrench)
Before that... I was using a "long handled" 1/4" ratchet with a socket before that. I had plenty of room for both...
Old Mar 2, 2008 | 07:56 PM
mattd17's Avatar
mattd17
it actually requires a 4mm wrench... and that is as per the owners manual.
Old Mar 3, 2008 | 08:52 AM
dfishrmn88's Avatar
dfishrmn88
SOMEBODY must have an idea how high off the ground the headlights should be adjusted to! I can't find it anywhere, even the manual. I just installed a 2" leveling kit and don't want to be flashed for "brights on" all the time or blind somebody!
Old Mar 3, 2008 | 09:59 AM
mattd17's Avatar
mattd17
what i did for mine, was to park in front of my garage about 1 foot from the door..... then measure the height of the beam concentration from the ground. then back up about 25 feet, and adjust the lights so the concentation is slightly lower than the original measurement. this way they arent going straight out, but down just a touch....... and there arent any side to side adjustments, so its real quick to do.
Old Mar 3, 2008 | 10:19 AM
FTE Ken's Avatar
FTE Ken
Instructions for adjusting headlights don't vary by ride height. You measure the height of the center of the headlight housing. Mark this height on a wall. Back up 25 feet and make the top of the beam about 1 inch below this mark.
Old Mar 3, 2008 | 10:37 AM
F0rdzTuff's Avatar
F0rdzTuff
You beat me to it....I was dropping my truck off since the compressor quit working on it Saturday.
Old Mar 3, 2008 | 11:35 AM
78moneypit's Avatar
78moneypit
SAE I assume
At 25 feet back (on level ground), the top edge of the 'high intensity' part of the beam pattern should be even with a reference line the same height as the center of the headlamp assembly. Look for a little circle on the lens to identify the center.
Old Mar 3, 2008 | 03:33 PM
dfishrmn88's Avatar
dfishrmn88
Thanks! That puts it in perspective.
InsanePyro
May 22, 2017 09:37 AM
quincyj34
Nov 10, 2015 03:58 PM
cliffhanger228
Sep 2, 2015 04:59 AM
AlM
1978 - 1996 Big Bronco
Nov 16, 2002 11:51 AM
narcicus
Apr 3, 2001 08:59 PM
