Overheating! Ignition Module??
Old Jun 9, 2001 | 07:19 PM
Katt's Avatar
Katt
Greetings,
My 1988 F-150 351W is overheating. The following parts are under warranty so I replaced them to no avail: Thermostat, Water Pump, radiator cap. I have also chemical flushed the system and put in new fluid. My only other thought is that the engine timing is incorrect, which would mean a faulty Ignition Control Module, right?
What do ya'll think?
Thanks much!!
Old Jun 9, 2001 | 10:21 PM
knuckles's Avatar
knuckles
I've never seen a failing ignition module cause an overheating problem.
Look at the rest of the cooling system first. Is the front of the radiator covered with bugs/leaves/debris? Is the fan clutch engaging when the engine warms up?
If the cooling system is indeed ok, check the ignition timing. It should be 10 degrees BTDC with the SPOUT connector removed.
If both the cooling system and the ignition timing are ok, check for a restricted exhaust system (clogged cat, collapsed pipe, etc.)
Let us know what you find.
Old Jun 10, 2001 | 07:13 PM
carlos57's Avatar
carlos57
You didn't slip a piece of cardboard in the grill last winter did you? Maybe a former owner? If it's between the air conditioning unit and the radiator you might not be able to see it unless you pull off a rubber seal on the top side which just directs air flow thru the radiator and look down in between.
Carlos
Old Jun 10, 2001 | 09:20 PM
absolutroscioli's Avatar
absolutroscioli
stensonv
Crossovers
May 14, 2017 02:49 PM
50jersey
16
Nov 1, 2016 11:43 AM
StoneHarding
Jul 10, 2016 11:00 AM
50monte
Dec 26, 2015 08:50 PM
mando77
Jun 17, 2010 01:23 PM
