Ignition Coil Overheating
Old Jul 10, 2016 | 03:40 AM
StoneHarding's Avatar
StoneHarding
I own a 1977 F-150 shortbed with a 351 engine. I'm having issues with the ignition coil overheating. I'll drive it around for about 30 minutes and then the engine will chug and eventually just die. If I cool down the coil by putting a bag of ice on it, it will start back up and run for another 30 minutes until overheating and dieing again. Ive made sure it's been wired correctly. I get 6.5v at the positive side of the coil with the key in run. I recently replaced the cap and rotor, spark plugs, and spark plug wires.
Here's the diagram I used
Here's a pic of my ignition coil
The 2 wires on the bottom attach to the positive lead one is the resistor wire and the other is the start bypass wire from the solenoid "I" terminal. The wire on the top is coming from my duraspark 2 ignition module. It's a green wire and label "tach" on the diagram. (Sorry pic is tilted)
I just don't know what could be causing the coil to overheat. Could an unproper ground cause it to overheat? Bad ignition module? Or maybe just the location, being close to the engine?
Old Jul 10, 2016 | 11:00 AM
HIO Silver's Avatar
HIO Silver
Has it dawned on you that the coil itself could be defective? I mean, the voltages checked out, right?
And if replacing, avoid Chinese made coils.
MitchellD
19
Aug 5, 2017 08:14 PM
tomdorf
Jan 9, 2011 10:31 PM
oldcarnut
Apr 19, 2004 10:59 PM
havinfun
Sep 27, 2003 08:48 PM
fordtrck302
Electrical Systems/Wiring
Jun 23, 2002 04:22 PM
