code 1280
Old Mar 22, 2019 | 11:02 AM
crazymut's Avatar
crazymut
code 1280
Pulled code 1280 on my truck, ICP out of range (low). Does this mean the switch is bad?
Old Mar 22, 2019 | 11:34 AM
DieselDenny's Avatar
DieselDenny
Terry,
if it's running allright I would clear the code and see if it pops back up in a few drive cycles. If it's running bad what are the symptoms? IE: stumbling or stalling or no start?
Denny
Old Mar 22, 2019 | 11:35 AM
crazymut's Avatar
crazymut
It's running fine. Cleared codes last night and it's back this morning after two drive cycles
Old Mar 22, 2019 | 12:23 PM
DieselDenny
Thinking the sensor is working part time.
Only way that I know to see if that's it...............replace with an OEM unit.
Not 100 pct sure but others will come along.
Good luck,
Denny
Old Mar 22, 2019 | 12:30 PM
DieselDenny
Terry,
Afterthought?? Have you pulled and inspected the sensor plug??? See if there's oil on it. If so, new sensor and clean the pigtail with electronics cleaner or brake cleaner.
Look for frayed wires as well.
You can also start the truck if it's dry and unplug the sensor. If the idle changes. Sensor is good and something else is up.
Denny
Old Mar 22, 2019 | 12:37 PM
crazymut's Avatar
crazymut
Yes there is oil on/in the plug
Old Mar 22, 2019 | 12:48 PM
DieselDenny
Take the above procedure into play and replace with motorcraft only.
Thinking a 5/8 open/ wrench.
BTW, since it's behind the alt, I would disconnect the neg terminals for safety unless your a surgeon.
Let us know what happens.
Denny
Old Mar 22, 2019 | 01:54 PM
crazymut's Avatar
crazymut
Bought new OEM ICP, installed, cleared codes, now need to complete test monitor drive cycle. BTW, it's a 3/4 in. wrench,socket
crazymut
Mar 22, 2019 10:50 AM
menesesjesse
1978 - 1996 Big Bronco
Sep 29, 2011 06:30 PM
Texas450
6.4L Power Stroke Diesel
Dec 17, 2010 10:52 AM
tholt34
Mar 7, 2007 08:58 AM
johntucker09
2004 - 2008 F150
Apr 19, 2006 09:48 PM
