its throwing a code now...
Old Apr 18, 2006 | 07:57 PM
johntucker09's Avatar
johntucker09
it had been running a little rough...
DTC D950
Does anyone know what this code is?
Thanks...
Old Apr 18, 2006 | 08:53 PM
superrangerman2002's Avatar
superrangerman2002
I haven't ever seen a "D"950 code. Usually codes follow the format Pxxxx.
Here's a neat chart that might be of use.
https://www.ford-trucks.com/article/..._Overview.html
Old Apr 18, 2006 | 08:56 PM
johntucker09
i have read that thing over and over...i didn't see anything...
Old Apr 18, 2006 | 09:11 PM
96f150's Avatar
96f150
How?
How did you come up with the 950? Did you get it from a specific code reader?
Old Apr 18, 2006 | 09:17 PM
johntucker09
the new computers give you a readout in the message center...
Old Apr 18, 2006 | 09:50 PM
Flash's Avatar
Flash
Here is everything you will ever want to know about your computer system from Ford. Get a sandwich, a drink, and reading glasses- it's 141 pages of pdf.
http://www.motorcraftservice.com/vdi...f/OBDSM601.pdf
Old Apr 19, 2006 | 12:55 PM
johntucker09
it wasn't in there either, but i did save that...its got some good stuff in it...
Old Apr 19, 2006 | 05:14 PM
Johnnyboy04's Avatar
Johnnyboy04
http://www.iequus.com/obd_def.asp
You can look up diagnostic codes at this website but I tried the code you gave and it doesnt come up with a match.
Old Apr 19, 2006 | 09:48 PM
xtrm1stang's Avatar
xtrm1stang
What you did is get a code from the instrument cluster- it is not necessarlly a code, but information on certain settings from part # to serial # to ammout of memory to final build and test date of the cluster, you need to ahve the pcm checked for codes with a scanner by someone who knows what they are doing
KCMAGERS
May 8, 2007 12:36 AM
WXboy
1983 - 2012 Ranger & B-Series
Nov 6, 2002 08:13 AM
Quantrex
Sep 2, 2002 06:53 PM
May 3, 2002 01:31 AM
Pastmaster
May 1, 2002 07:05 PM
