1978 - 1996 Big Bronco
Fixed my Code 565 error
Old Sep 29, 2011 | 01:04 PM
menesesjesse's Avatar
menesesjesse
In my quest to fix all the anomalies my Bronco came with I came to the final one. This fault did not cause my CEL to go on and there was no running issues noticed either. My scanner just happened to pop this code every time I did a code check on my scanner. Turns out that the EVAP selenoid was faulty. It was sticking inside preventing the switch from operating. When I ran the scanner it always came up as an inoperable during the initial tests of pumps and switches. I replaced it with a used one from the junk yard and I have finally gotten to the 111 code. Truck runs very well now and I am happy to have found a used switch because Ford wants 90 bucks for it. Hope this helps someone.
Old Sep 29, 2011 | 06:30 PM
rla2005's Avatar
rla2005
Thanks for the feedback! I am sure it will come in handy for others.
crazymut
Mar 22, 2019 10:50 AM
KHADIJE22
6.4L Power Stroke Diesel
Oct 23, 2011 08:40 AM
winter123
1997 - 2003 F150
Sep 27, 2009 07:50 AM
johntucker09
2004 - 2008 F150
Apr 19, 2006 09:48 PM
