Hood spring
Old Mar 21, 2019 | 03:09 PM
caravaggio2000's Avatar
caravaggio2000
Hood spring
The front of my hood is always sticking up about an inch and a half. You can push it down level, but it pops back up. Everything else is nicely aligned.
So, today I took out the spring at the front that keeps the hood from slamming down (the one opposite the latch that sits near the top of the radiator) and bam! Everything lines up perfectly.
Has anyone run into this? It looks like the correct spring. I am fine leaving it out and being careful when I close the hood, just wondering why this might have gotten out of line.
Old Mar 21, 2019 | 03:30 PM
73GreenBean's Avatar
73GreenBean
Wondering if you could move the latch mechanism up a little? Sounds the the spring could be mashed down and not allowing the latch to grip the little U bolt looking piece on the hood? Then when you remove the spring it allows the hood to seat firmly in the latch like it should. I'd try moving the latch mechanism up if you have any adjustment left before leaving the spring out. Just my .02
Old Mar 21, 2019 | 04:34 PM
Meridian_Mike's Avatar
Meridian_Mike
I don't think I would want to leave that spring out.... Maybe shorten it(?)
That spring provides tension to push the hood latch against the "hook" in the latch bar....
You might get a "SURPRISE" riding down the road when your hood flies up.....
Mike
Old Mar 21, 2019 | 04:48 PM
Meridian_Mike
Here is a hood latch diagram....
I suppose you are talking about removing spring.... 16C644...???
Mike
Old Mar 21, 2019 | 04:55 PM
caravaggio2000
Well you guys are geniuses. Here I was thinking the latch needed to move downward, but moving it up did the trick (with the spring back on). Thanks.
Yes, it was 16c644 (and yes, I had my 79 Bronco hood fly up on me going 70mph and that is not something I wish to repeat.)
Old Mar 21, 2019 | 04:59 PM
Meridian_Mike
GreenBean....
You da man.... You already had that situation figgered out din't ya'..??
Old Mar 21, 2019 | 07:45 PM
73GreenBean
Well Mike I've just learned that trial and error is the best source of learning sometimes lol! Glad you got it figured out though, best of luck with your progress!
Old Mar 21, 2019 | 11:17 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Hood adj 101: https://www.ford-trucks.com/forums/s...&postcount=131
Old Mar 22, 2019 | 06:51 AM
Meridian_Mike
I'm glad you gave a link to the hood adjustment thread Rich....
I'm gonna need it when I get to the point of putting my hood back on.
Mike
kadrocker
Jun 7, 2015 12:59 AM
John R. Thomas
Jul 15, 2014 06:34 PM
Rich56
Apr 10, 2013 01:03 PM
pademc
Feb 19, 2004 03:41 PM
