Door Mechanism
Old Mar 21, 2019 | 07:04 AM
diamondrcattle's Avatar
diamondrcattle
Door Mechanism
F 250 High boy 1973, I need the guys for the door mechanism inside the door, not handles. It is worn out. Looked at LCM trucks, but show every thing but the mechanism. Any ideas where I can find?
Old Mar 21, 2019 | 08:46 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1973/79 F100/350 & 1978/79 Bronco is the same.
Pic: Which part(s) are you asking about?
Old Mar 21, 2019 | 01:00 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
....PM sent.... my guess is 21818 is worn out.
Old Mar 22, 2019 | 10:58 AM
HoustonDave's Avatar
HoustonDave
Possible quick fix - door mechanisms can gunk up, especially if someone hosed it down with WD40 in an attempt to ungunk it. Try pulling it and thoroughly cleaning it before writing it off.
Old Mar 22, 2019 | 12:32 PM
EQCMCAT's Avatar
EQCMCAT
If problem is associated W/part # 21818, carefully inspect the metal mounting base behind and surrounding part # 21818. Similar design W/my 95 F-150, I had to weld the interior of the door where the door mechanism part # 21818 mounts too, the metal was cracked, seems to get fatigued over time.
DisneysPatB
Nov 22, 2017 06:43 AM
cougardude70
WTB - Parts & other
Feb 14, 2017 05:05 PM
ericthor
22
Oct 13, 2016 04:54 PM
beaudog
May 14, 2016 04:43 PM
Quadiquizm
Apr 14, 2003 06:46 AM
