Lug nut torque
Old Jan 24, 2026 | 01:18 PM
  #106
mikeinAiken's Avatar
mikeinAiken
4th Gear
86 tford truck lug nut torque setting
Originally Posted by BigBlue2
So cutting to the chase, what torque do you recommend for an 80-86 F250 with 9/16" diameter, 8 stud steel truck wheels? Indicate whether you recommend dry torque or lubricated and describe the proper maintenance for the studs. Same question for trucks with 5 lug 1/2" diameter studs?
I know it i an old thread but I found nobody posting the Ford shop manual specs. The 86 Ford Truck Shop manual for body chasis and electrical call for dry threads and 100 ft lbs torque.
Old Jan 24, 2026 | 02:11 PM
  #107
Franklin2's Avatar
Franklin2
That is something I will never agree with. Using no lubrication on lug studs. I do not care if they are Ford and have 20 years of engineering degrees.
Old Jan 24, 2026 | 06:42 PM
  #108
BigBlue2's Avatar
BigBlue2
The proper thread condition is rust free. Not lubricated. But rust free does imply a micro thin coating. Wipe em clean and torque em down. If you're me, you're checking the torque every 100 miles or so till they are set. Usually two checks and you're good to go. Steel wheels roll so sweet when they are properly torqued in a star pattern. I swap out mine with winter rims and tires so torquing up twice every year.
urbex
Large Truck
Oct 10, 2017 01:36 PM
Connecticut Calvin
Sep 29, 2015 08:47 AM
gmammakn
May 17, 2010 11:50 PM
packrat56
Garage & Workshop
Jan 2, 2008 03:02 PM
CallieDo02
Oct 25, 2007 08:07 PM
