Sponsored by: Kumho
Lug Nut Torque?
Old Oct 18, 2007 | 04:47 PM
CallieDo02's Avatar
CallieDo02
Lug Nut Torque?
I have an RV on an 06 E450 chassie, 16 in wheels. To what should I torque the rear duals and the front wheels?
Old Oct 19, 2007 | 08:37 PM
blue beast's Avatar
blue beast
Probably in the 250ftlbs range I would look into finding exactly you definately don't want them to be too loose or stretch the studs. When you do find the rating, Do a search for torque stick it is a preset extension that makes a click at the pre set
torque rating, It is basically a torque wrench but it goes on your breaker bar as an extension to your socket and it is a lot cheaper than big torque wrench that reads up that high!! The torque wrench we were using for the trucks was $600.00 and it went
to 600ftlbs. The torque stick is less then a $100.00 If I remember right.
Old Oct 25, 2007 | 07:00 PM
ynevada's Avatar
ynevada
is that a washer type nut? it might say right on the washer itself. otherwise, id say around 140-150.
250 sounds high.
its only a 450 chassis.
Old Oct 25, 2007 | 08:07 PM
blue beast's Avatar
blue beast
http://www.torquestick.com/cart/cust...0&cat=1&page=1
They say gauranteed accurate within 4% or whatever with a air impact but we use
to hire a owner operater he had the 475 ftlb one and he used it with a breaker bar
and it was accurate I compared it to our big snap on torque wrench and it was right
there. I guess they are a lot cheaper than I thought if you just buy them single but
it still isn't a bad price for the multiple kit compared to some torque wrenches out there
I said 250 guessing better to go over if he was going to torque it by hand I just
wanted to make sure he went for a bit more torque than a normal truck would take.
If it has those workhorse axles they have a crazy high torque rating so make sure you
find out exactly what you have on that truck, I don't know what those workhorse
came on but they are 475 ftlbs , the mechanics buddy used to come and use our torque wrench on his rv to torque them he left it set (which is a bad bad thing to do to a spring torque wrench!!) to 475 ftlbs I asked him if his buddy
like to see his lug nuts fly off going down the road and he said that's what those type
called for, That's more than my MACK dump truck takes!!
TransBrain
Jul 20, 2014 05:19 PM
BigBlue92
Feb 23, 2011 07:55 AM
garrettallison
Apr 17, 2007 10:26 PM
slund42
Jun 18, 2006 06:26 AM
briski04
Jun 9, 2002 10:55 PM
