bilstein ride quality
Old Mar 20, 2019 | 06:39 PM
Dylan Kamm's Avatar
Dylan Kamm
i just got my f150 back from Ford and they installed a bilstein 5100 leveling kit in the front. it was set at 2.25" of lift. I am running brand new 20x10 fuel mavericks on 33" nitto ridge grappler. immediately I noticed how horrible the ride quality is. you hit a little tiny bump and you just sit there and bounce. wondering if anyone else had this problem and what was the solution. thanks
Old Mar 20, 2019 | 07:31 PM
steve(ill)'s Avatar
steve(ill)
you better go back to FORD and have them drive it and look it over... Bilstein should NOT do anything like that.
Old Mar 20, 2019 | 07:51 PM
Dylan Kamm's Avatar
Dylan Kamm
[QUOTE=steve(ill);18551651]you better go back to FORD and have them drive it and look it over... Bilstein should NOT do anything like that.[/QUOTE
the manager drove in the parking lot and he said "it rides stiff but that's what you wanted" no that's not what I wanted. it took them 2 days to install the front adjustable struts. it is set on the highest setting so if I drop it down an inch will the ride quality change? I'm calling bilstein first thing in the morning to see what is going on. thanks
Old Mar 21, 2019 | 04:12 PM
2009kr's Avatar
2009kr
When I put Bilstein 5100s on the back of my 2009 F150, the ride was way stiffer. I liked the stock shock ride MUCH better. Actually, 120,000 miles later, I still have them on the back of my truck. Maybe I'll finally replace them with something softer, maybe the RS9000XLs like the ones that I have on my F450.
Old Mar 25, 2019 | 06:14 PM
P.Bronner's Avatar
P.Bronner
The Bilstein's will be quite stiff when pre-loaded to +2.25". The better route for that much level is to use a 1.5" leveling spacer and run them in notch #2 (.75").
h20camper
Aug 10, 2017 09:19 AM
mattmck
May 20, 2015 02:22 PM
fx4king2011
2009 - 2014 F150
Nov 23, 2014 12:01 AM
jgwyatt
Apr 7, 2013 01:29 AM
timmyjimmy5150
Mar 12, 2006 08:47 AM
