Excursion Vibration - What Next???
Old Mar 21, 2019 | 04:34 PM
pirate4x4_camo's Avatar
pirate4x4_camo
Driveline takes 10 minutes to remove.
Old Mar 21, 2019 | 04:52 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
This is true^^^
Old Mar 22, 2019 | 05:40 AM
msuser92's Avatar
msuser92
Originally Posted by Nicmike
This is true^^^
Says all you non rust belt guys. LOL
Old Mar 28, 2019 | 11:13 AM
inthedirt's Avatar
inthedirt
Had a noise (not vibration) present upon deceleration only when my Ex was lifted 8in or so. Have no idea if the DS were replaced/lengthened, but on jackstands and running gear turning about 50mph, I crawled underneath and gave a listen (ballsy, I know). Saw just how much slop was in the DS and could tell it was coming from the slip yoke. Front end had more slop, but the noise was definitely coming from the rear DS. Cleaning and re-greasing made no difference. Once I lowered the front and rear about 3.5-4in last summer, the noise completely disappeared as the splines on the yokes were able to make better contact.
Old Apr 4, 2019 | 10:11 AM
bigpoppapeak's Avatar
bigpoppapeak
Final Verdict - It was a combination.
First issue -
  • Measured the Pinion angle and was out 4 degrees.
  • Installed 4 Degree shims.
Results - Vibration Halfway gone but still noticeable.
Second Issue -
  • Drove in Front wheel drive (Rear Driveshaft removed) full spectrum 0mph thru 85mph, Vibration completely gone.
  • Had Driveshaft rebuilt - New Flanges, U-joints, balanced.
Results - Vibration Completly Gone.
As for the apparent galling on the carrier, Who Knows. It does not appear to be affecting the performance and I can't feel anything rubbing so I will leave it for now.
Old Apr 4, 2019 | 11:29 AM
wizkid00104's Avatar
wizkid00104
Good to hear. What did the charge for the rebuild and balance on the shaft?
Old Apr 4, 2019 | 11:39 AM
bigpoppapeak
I really hate to say, but because it is my daily and he did it overnight, I spent $300.00
Old Apr 4, 2019 | 11:54 AM
pirate4x4_camo
Glad that worked out,
I am a bit surprised you needed a 4* shim with a 3.5 lift. Any chance you can post a pic of the rear suspension and driveshaft ? Something seems fishy.
fwiw $300 sounds reasonable for a rebuilt shaft that has new flanges and joints, especially if he built it for “rush” status.
I pay $450 for mine but I use .120 wall cromoly tubing so that adds considerably to the material cost.
Old Apr 4, 2019 | 12:02 PM
RPhil's Avatar
RPhil
First issue -
Second Issue -
Thanks for following up. I'm suspecting my issue is similar to yours. Which shims did you buy?
Old Apr 4, 2019 | 12:05 PM
2003EXV10's Avatar
2003EXV10
Glad it all worked out. I’m bookmarking this thread for future use. Thanks for all the info!
Old Apr 4, 2019 | 12:20 PM
pirate4x4_camo
just a hunch but I think he bought the 4 degree ones
Old Apr 5, 2019 | 12:14 PM
wizkid00104
I agree with Pirate, for the labor involved that doesn't seem bad at all. In theory it's not a difficult job, but you made the comment on the rust. Pressing rusty u-joints can be a chore. Even torching them takes some time.
Old Apr 8, 2019 | 09:14 AM
  #28
bigpoppapeak
I think the $300 was excessive because he removed 2-week old Spicer serviceable U-Joints and replaced them and the OEM flanges with these really chincy looking "Neapco" flanges and U-Joints. Charged me $80 for the flanges and I KNOW I can get the heavy Spicer ones for $50.
When they say things like "this is the worst I have ever seen" and "Who else are you going to get to do it", grab the vasoline.
noimports
Apr 22, 2018 09:08 AM
vulcrider
1983 - 2012 Ranger & B-Series
Aug 16, 2016 09:19 AM
MSC
Feb 10, 2006 08:20 PM
mmx2000
Dec 29, 2003 07:44 PM
gammer2000
1978 - 1996 Big Bronco
Aug 23, 2001 02:00 PM
