1978 - 1996 Big Bronco
vibration problem
Old Aug 12, 2001 | 07:30 PM
gammer2000's Avatar
gammer2000
vibration problem
I have a 78 bronco that has a vibration at about 25 mph and under during braking or not,its just worse when I brake,everything brake wise on the rear has been replaced,the vibration is not as noticable at constant speed,can anyone help......
Old Aug 13, 2001 | 07:07 AM
Bob_VT's Avatar
Bob_VT
vibration problem
90% of the time vibration while braking is a result of "rotor runout". You might want to check your front rotors, they might have worn too thin. They tend to also warp if they are this thin. Check them out.
Old Aug 13, 2001 | 09:13 AM
gammer2000's Avatar
gammer2000
vibration problem
it still vibrates even if I dont apply the brakes,it feels like it starts from the rear and moves forward
Old Aug 13, 2001 | 06:53 PM
Bob_VT's Avatar
Bob_VT
vibration problem
If it is bouncing almost like a ball then you also need to check the steering stabiliser. Just remove one end and work it in and out. It should feel just like a good shock absorber. If there is no resistance and you are able to move it too easy OR if it binds and does not travel smooth. Replace it.
Old Aug 14, 2001 | 10:25 AM
gammer2000's Avatar
gammer2000
vibration problem
it feels more like something in the driveline to me,not really in the steering wheel,where elese can I look for problem parts,any more ideas would be helpful.......thanks
Old Aug 14, 2001 | 04:26 PM
Bob_VT's Avatar
Bob_VT
vibration problem
Can you drive past the vibration like go faster past that point?
You really should get your U-joints checked. They might not be worn out however I have had them seize up. As a matter of fact when I replaced a seized up one on my 84 Bronco my gas mileage got better.
Old Aug 15, 2001 | 08:24 AM
gammer2000's Avatar
gammer2000
vibration problem
I will get them checked out,thanks for the info,hopefully this will fix my problem.......
Old Aug 22, 2001 | 02:50 PM
honney's Avatar
honney
vibration problem
Old Aug 22, 2001 | 08:06 PM
Bob_VT's Avatar
Bob_VT
vibration problem
Just wanted to kick this back to the top of the board. Well, is the vibration fixed? What was it?
Old Aug 23, 2001 | 10:42 AM
1911bronco's Avatar
1911bronco
vibration problem
If you suspect the driveline...I would first check the slip joint at the rear of your driveshaft....Mine felt tight untill I pulled it apart...that is when I discovered 1/2 of the splines were worn to nothing....also...the centering ball on the front cardon...to make a long story short...I had a similar vibration...$180.00 to a local driveshaft place...for a brand new driveshaft that they also balanced....and...my vibration is gone.
good luck
Greg
Old Aug 23, 2001 | 02:00 PM
sideout2's Avatar
sideout2
vibration problem
One thing you may also want to check is the track bar bushings. Mine were worn out and where the track bar bolts to the shock tower was lose.
stlrfan1
1983 - 2012 Ranger & B-Series
Jun 20, 2013 08:07 PM
1trik76
1997 - 2003 F150
Jul 14, 2009 08:55 AM
greenterror
Mar 20, 2007 08:30 AM
84F150-4x4
Apr 1, 2004 10:00 PM
onsitewv
Oct 4, 2003 04:24 PM
