Excursion Vibration - What Next???
between 58 and 73 MPH. Vibration seems to be coming from the rear of the vehicle. There is a slight torque component to the vibration (feels different when under power (foot in throttle) vs. slack (foot out of throttle). I will describe sequences leading up to today:
1) Replace all leaf spring, sway bar, track bar, even body mounts with urethane bushings.
2) Add-A-Leak on all 4 leaf packs. Doesn’t fit the profile listed in the Vibration Diagnosis Details over in the tech folder, added for consideration. Vibration began 2500 miles after this work was complete.
3) Installed Roadmaster active suspension. Again doesn’t meet the profile, added for consideration. Vibration began 2500 miles after this work was complete.
4) Installed Sulastic Rubber Springs/Shackles on front and rear leaf springs. Again doesn’t meet the profile, added for consideration. Vibration began 2500 miles after this work was complete.
5) Installed Hellwig rear sway bar. Again doesn’t meet the profile, added for consideration.
6) In concert, the 5 items above were done simultaneously and resulted in 3.5 inches of lift. But again vibration began 2500 miles after this work was complete so I don't think pinion angle is the problem.
7) Replaced Upper and Lower Front Ball Joint. Doesn’t meet the profile, added for consideration. Vibration began 1000 miles after this work was complete.
8) Tires Rotated/Balanced - No Change in Vibration.
9) New U-joints in Drive Shaft and Greased the slip joint – Vibration slightly got worse.
Took to a transmission shop (quality of workmanship unknown) for differential servicing and inspection in hopes that this would result in something meaningful in this vibration chase. During the inspection, the technician sent me the below pictures and said: “I’ve never seen anything like this in my 30 years in the business”.
He closed up the Diff, filled with fluid and said: "Nothings rubbing, here's your bill, good luck."
Not sure what to do Next. Anybody ever seen this kind of gauling on a carrier?
Pirate4x4 should be along shortly to comment here. He is an expert in this arena of discussion.
Is 3.5 inches of lift enough to put the pinion and rear-end angle into an out of phase condition?
Edit: The driveshaft could've cause the problem the problem if it is the pinion bearings. Abnormal stress on the pinion yoke destroyed the bearings. But at 350k miles, it may just be worn out especially if the fluid was not regularly serviced.
Remove the rear drive shaft
test drive in front wheel drive.
if the vibration is present when the rear driveshaft is removed then the issue is in the rear axle/wheels
if the vibration is gone then the issue is either your rear pinion angle or as noted above a ujoint or the slip yoke.
Is it “safe” to drive 60-80 mph in the front drive only configuration? My truck has seen very little engagement of the front driveline, but I know it’s all functional.
you can drive at 55 mph in 4 high as long as you are not on dry pavement, with the rear driveline taken off the vehicle there will be no binding. When you drive in 4x4 with the rear driveline installed the front and rear are locked together and the tires need to be able to slip ( like on a dirt road or snow ) to eliminate the bind.
but if I were to guess it is your pinion angle after the spring changes, but the slip yokes is also a good candidate since where the spline are engaging inside of it has also changed after you altered the ride height. Basically anything that was changed when you altered the ride height is most suspect, Or it could just be coinsidence and something else wore out just so happened to after the change..... those would be ujoints, tires, rim, ect.
entirely possible the new driveline angle pissed off your ujoints so they decided now would be a good time to fail, or maybe your wife hit a curb and bent a rim and forget to mention it to you..... but that never happens.
I am getting my drive shaft back in the morning. He told me the 2 inch lift is still within operating range of the slip joint. My new measurement from flange to flange is 52 5/16"...you might check yours for comparison. $87 to balance and re-phase mine.
