E4OD Wrong shift solenoid???
Old Mar 19, 2019 | 01:02 PM
mmagang's Avatar
mmagang
I recently bought a 1996 F350 7.5L. The original transmission went out in it and the previous owner installed an E4OD out of a 1993. He was telling me that since the 96 has a different solenoid than the 93 transmission, that it might have trouble shifting. Well i am running into this now. 2nd gear will kick in and out then go straight into 3rd. All other gear are 100%. Fluid is full and nice and red. My question is do you think if i put 96 solenoid in that it would solve the problem. Or can i even put a 96 solenoid pack into the 93?
Old Mar 19, 2019 | 02:19 PM
sandymane's Avatar
sandymane
The E4OD is electronically controlled. We might get some good info on what is going on if you run the diagnostic codes. If you are OBD 1 instead of OBD 2 you can get help here on how to pull codes if you are unfamiliar with how to do it. The 93 will be from an OBD 1 for sure, the truck being a 96 could be OBD 2. If OBD 2 truck, your plug in will be under the dash. Either way the computer should tell us something. Sandy
Old Mar 19, 2019 | 07:32 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
You can put either solenoid body in either transmission. The difference is a diode, it's not going to affect the shifting.
I agree you need the codes to figure this out.
Zapp911
Oct 11, 2022 03:32 PM
jonathanl
Jan 9, 2018 09:45 AM
farnorcal logger648
Aug 16, 2015 07:22 AM
ml8on
1978 - 1996 Big Bronco
15
Apr 23, 2014 11:58 AM
JCATC
Apr 8, 2004 07:15 AM
